RTEMS Tools on 5 release can't be build with modern LLVM
Joel Sherrill
joel at rtems.org
Mon Aug 16 15:03:00 UTC 2021
On Mon, Aug 16, 2021 at 9:49 AM Christian MAUDERER
<christian.mauderer at embedded-brains.de> wrote:
> Hello,
> I noted that I can't build the RTEMS 5 toolchain if I have a modern LLVM
> installed using the RTEMS source builder. Therefore I would like to
> backport the patch 37ad446d9dce3 ([1]) to the 5 branch. Is that OK? If
> someone acknowledges it, I would do the following steps without further
> review (but of course with testing):
> 1. Create a ticket for the problem.
> 2. In rtems-tools: Cherry pick the patch 37ad446d9dce3 to the 5 branch.
> 3. In rtems-source-builder: Backport the patch 91932d0a0 [2] to the 5
> branch (or rather re-create it because it will be a different commit and
> a different hash).
I'm ok with this. I remember doing a patch for the opposite direction.
I couldn't
build on an older gcc because it assumed a different language version as
default. gcc 4.8 as on CentOS 7 assumes C++03. Newer versions assume C++11
as the base. Similarly newer gcc's seem to default to C11.
I posted a few weeks ago that users should really be careful to always use
-std and consciously pick what they want.
--joel
> Best regards
> Christian
> [1]
> https://git.rtems.org/rtems-tools/commit/?id=37ad446d9dce3438d6d32e1caf56d3fdccdd2ad0
> [2]
> https://git.rtems.org/rtems-source-builder/commit/?id=91932d0a0c86400366f9c75a62123b6488ff458a
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
