[PATCH] Confstr support for RTEMS
Joel Sherrill
joel at rtems.org
Wed Aug 18 14:27:55 UTC 2021
This is merged.
Thanks for sticking with this. :)
On Sun, Aug 15, 2021 at 2:58 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> From: Eshan dhawan <eshandhawan51 at gmail.com>
> Closes #3373
> Confstr style update
> Signed-off-by: Eshan Dhawan <eshandhawan51 at gmail.com>
> cpukit/Makefile.am | 1 +
> cpukit/posix/src/confstr.c | 127 ++++++++++++++++++
> spec/build/cpukit/librtemscpu.yml | 1 +
> spec/build/testsuites/psxtests/grp.yml | 2 +
> spec/build/testsuites/psxtests/psxconfstr.yml | 20 +++
> testsuites/psxtests/Makefile.am | 9 ++
> testsuites/psxtests/configure.ac | 1 +
> testsuites/psxtests/psxconfstr/init.c | 97 +++++++++++++
> testsuites/psxtests/psxconfstr/psxconfstr.doc | 17 +++
> testsuites/psxtests/psxconfstr/psxconfstr.scn | 4 +
> 10 files changed, 279 insertions(+)
> create mode 100644 cpukit/posix/src/confstr.c
> create mode 100644 spec/build/testsuites/psxtests/psxconfstr.yml
> create mode 100644 testsuites/psxtests/psxconfstr/init.c
> create mode 100644 testsuites/psxtests/psxconfstr/psxconfstr.doc
> create mode 100644 testsuites/psxtests/psxconfstr/psxconfstr.scn
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index dfa5fb2412..1afac8f7dc 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -509,6 +509,7 @@ librtemscpu_a_SOURCES += posix/src/condsignalsupp.c
> librtemscpu_a_SOURCES += posix/src/condtimedwait.c
> librtemscpu_a_SOURCES += posix/src/condwait.c
> librtemscpu_a_SOURCES += posix/src/condwaitsupp.c
> +librtemscpu_a_SOURCES += posix/src/confstr.c
> librtemscpu_a_SOURCES += posix/src/_execve.c
> librtemscpu_a_SOURCES += posix/src/fork.c
> librtemscpu_a_SOURCES += posix/src/key.c
> diff --git a/cpukit/posix/src/confstr.c b/cpukit/posix/src/confstr.c
> new file mode 100644
> index 0000000000..e814b3c6d7
> --- /dev/null
> +++ b/cpukit/posix/src/confstr.c
> @@ -0,0 +1,127 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @brief Implementation for confstr method
> + * Copyright (C) 2020 Eshan Dhawan
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <sys/cdefs.h>
> +#include <sys/param.h>
> +#include <errno.h>
> +#include <limits.h>
> +#include <string.h>
> +#include <unistd.h>
> +/* Many programming environment flags have same values
> +* this block is added to raise error if the flags value change
> +#if (_CS_POSIX_V6_ILP32_OFF32_CFLAGS != _CS_POSIX_V7_ILP32_OFF32_CFLAGS)
> +#error "_CS_POSIX_V6_ILP32_OFF32_CFLAGS and _CS_POSIX_V7_ILP32_OFF32_CFLAGS flag values not equal"
> +#endif
> +#if (_CS_POSIX_V6_ILP32_OFF32_LDFLAGS != _CS_POSIX_V7_ILP32_OFF32_LDFLAGS)
> +#error "_CS_POSIX_V6_ILP32_OFF32_LDFLAGS and _CS_POSIX_V7_ILP32_OFF32_LDFLAGS flag values not equal"
> +#endif
> +#if (_CS_POSIX_V6_ILP32_OFF32_LIBS!= _CS_POSIX_V7_ILP32_OFF32_LIBS)
> +#error "_CS_POSIX_V6_ILP32_OFF32_LIBS and _CS_POSIX_V7_ILP32_OFF32_LIBS flag values not equal"
> +#endif
> +#if (_CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS != _CS_POSIX_V7_LPBIG_OFFBIG_CFLAGS)
> +#error "_CS_POSIX_V6_LPBIG_OFFBIG_CFLAG and _CS_POSIX_V7_LPBIG_OFFBIG_CFLAG flag values not equal"
> +#endif
> +#if (_CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS != _CS_POSIX_V7_LPBIG_OFFBIG_LDFLAGS)
> +#error "_CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS and _CS_POSIX_V7_LPBIG_OFFBIG_LDFLAGS flag values not equal"
> +#endif
> +#if (_CS_POSIX_V7_LPBIG_OFFBIG_LIBS != _CS_POSIX_V7_LPBIG_OFFBIG_LIBS)
> +#error "_CS_POSIX_V6_LPBIG_OFFBIG_LIBS and _CS_POSIX_V7_LPBIG_OFFBIG_LIBS flag values not equal"
> +#endif
> +#if (_CS_POSIX_V6_ILP32_OFFBIG_CFLAGS != _CS_POSIX_V7_ILP32_OFFBIG_CFLAGS)
> +#error "_CS_POSIX_V6_ILP32_OFFBIG_CFLAGS and _CS_POSIX_V7_ILP32_OFFBIG_CFLAGS flag values not equal"
> +#endif
> +#if (_CS_POSIX_V7_ILP32_OFFBIG_LDFLAGS != _CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS)
> +#error "_CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS and _CS_POSIX_V7_ILP32_OFFBIG_LDFLAGS flag values not equal"
> +#endif
> +#if (_CS_POSIX_V7_ILP32_OFFBIG_LIBS != _CS_POSIX_V7_ILP32_OFFBIG_LIBS)
> +#error "_CS_POSIX_V6_ILP32_OFFBIG_LIBS and _CS_POSIX_V7_ILP32_OFFBIG_LIBS flag values not equal"
> +#endif
> +#if (_CS_POSIX_V6_LP64_OFF64_CFLAGS != _CS_POSIX_V7_LP64_OFF64_CFLAGS)
> +#error "_CS_POSIX_V6_LP64_OFF64_CFLAGS and _CS_POSIX_V7_LP64_OFF64_CFLAGS flag values not equal"
> +#endif
> +#if (_CS_POSIX_V6_LP64_OFF64_LDFLAGS != _CS_POSIX_V7_LP64_OFF64_LDFLAGS)
> +#error "_CS_POSIX_V6_LP64_OFF64_LDFLAGS and _CS_POSIX_V7_LP64_OFF64_LDFLAGS flag values not equal"
> +#endif
> +#if (_CS_POSIX_V7_LP64_OFF64_LIBS != _CS_POSIX_V7_LP64_OFF64_LIBS)
> +#error "_CS_POSIX_V6_LP64_OFF64_LIBS and _CS_POSIX_V7_LP64_OFF64_LIBS flag values not equal"
> +#endif
> +#if (_CS_V6_ENV != _CS_V7_ENV)
> +#error "_CS_V6_ENV and _CS_V7_ENV flag values not equal"
> +#endif
> +size_t confstr(int name, char *buf, size_t len){
> + const char *p;
> + const char UPE[] = "unsupported programming environment";
> + switch (name) {
> + case _CS_PATH:
> + errno = EINVAL;
> + return (0);
> + case _CS_POSIX_V7_ILP32_OFF32_CFLAGS:
> + case _CS_POSIX_V7_ILP32_OFF32_LDFLAGS:
> + case _CS_POSIX_V7_ILP32_OFF32_LIBS:
> + case _CS_POSIX_V7_LPBIG_OFFBIG_CFLAGS:
> + case _CS_POSIX_V7_LPBIG_OFFBIG_LDFLAGS:
> + case _CS_POSIX_V7_LPBIG_OFFBIG_LIBS:
> + case _CS_POSIX_V7_ILP32_OFFBIG_CFLAGS:
> + case _CS_POSIX_V7_ILP32_OFFBIG_LDFLAGS:
> + case _CS_POSIX_V7_ILP32_OFFBIG_LIBS:
> + case _CS_POSIX_V7_LP64_OFF64_CFLAGS:
> + case _CS_POSIX_V7_LP64_OFF64_LDFLAGS:
> + case _CS_POSIX_V7_LP64_OFF64_LIBS:
> + case _CS_V7_ENV:
> + p = UPE;
> + if (len != 0 && buf != NULL){
> + strlcpy(buf, p, len);
> + return (strlen(p) + 1);
> + default:
> + errno = EINVAL;
> + return (0);
> diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
> index 0abff9d439..48266d408b 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -1009,6 +1009,7 @@ source:
> - cpukit/posix/src/condtimedwait.c
> - cpukit/posix/src/condwait.c
> - cpukit/posix/src/condwaitsupp.c
> +- cpukit/posix/src/confstr.c
> - cpukit/posix/src/fork.c
> - cpukit/posix/src/key.c
> - cpukit/posix/src/keycreate.c
> diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
> index fb7ce465ae..8de96e7c7d 100644
> --- a/spec/build/testsuites/psxtests/grp.yml
> +++ b/spec/build/testsuites/psxtests/grp.yml
> @@ -89,6 +89,8 @@ links:
> uid: psxcond02
> - role: build-dependency
> uid: psxconfig01
> +- role: build-dependency
> + uid: psxconfstr
> uid: psxdevctl01
> diff --git a/spec/build/testsuites/psxtests/psxconfstr.yml b/spec/build/testsuites/psxtests/psxconfstr.yml
> index 0000000000..252fc4601d
> --- /dev/null
> +++ b/spec/build/testsuites/psxtests/psxconfstr.yml
> @@ -0,0 +1,20 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: test-program
> +cflags: []
> +copyrights:
> +- Copyright (C) 2020 Eshan Dhawan (eshandhawan51 at gmail.com)
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +features: c cprogram
> +includes: []
> +ldflags: []
> +links: []
> +source:
> +- testsuites/psxtests/psxconfstr/init.c
> +stlib:
> +- m
> +target: testsuites/psxtests/psxconfstr.exe
> +type: build
> +use-after: []
> +use-before: []
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index a35f00b665..02ccc9dfff 100755
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -358,6 +358,15 @@ psxconfig01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxconfig01) \
> $(support_includes) -I$(top_srcdir)/include
> endif
> +psx_tests += psxconfstr
> +psx_screens += psxconfstr/psxconfstr.scn
> +psx_docs += psxconfstr/psxconfstr.doc
> +psxconfstr_SOURCES = psxconfstr/init.c
> +psxconfstr_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxconfstr) \
> + $(support_includes)
> if TEST_psxdevctl01
> psx_tests += psxdevctl01
> psx_screens += psxdevctl01/psxdevctl01.scn
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
> index 3f95010cd3..1ad6cc58fe 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -80,6 +80,7 @@ RTEMS_TEST_CHECK([psxconcurrency01])
> RTEMS_TEST_CHECK([psxcond01])
> RTEMS_TEST_CHECK([psxcond02])
> RTEMS_TEST_CHECK([psxconfig01])
> +RTEMS_TEST_CHECK([psxconfstr])
> RTEMS_TEST_CHECK([psxdevctl01])
> RTEMS_TEST_CHECK([psxeintr_join])
> RTEMS_TEST_CHECK([psxenosys])
> diff --git a/testsuites/psxtests/psxconfstr/init.c b/testsuites/psxtests/psxconfstr/init.c
> index 0000000000..46738b067f
> --- /dev/null
> +++ b/testsuites/psxtests/psxconfstr/init.c
> @@ -0,0 +1,97 @@
> + * @file
> + * @brief Test suite for confstr method
> + * are met:
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <errno.h>
> +#include <stdio.h>
> +#include <rtems/test.h>
> +#include <rtems/test-info.h>
> +const char rtems_test_name[] = "PSXCONFSTR";
> +/* init test function begins */
> +T_TEST_CASE(confstr)
> + int r;
> + char * buf = "";
> + size_t len1;
> + len1 = strlen(UPE) + 1;
> + r = confstr(_CS_PATH, buf, sizeof(buf));
> + T_quiet_psx_success(r);
> + r = confstr(_CS_POSIX_V6_ILP32_OFFBIG_CFLAGS, buf, sizeof(buf));
> + T_quiet_eq_int(r, len1);
> + r = confstr(_CS_POSIX_V6_LP64_OFF64_LDFLAGS, buf, sizeof(buf));
> + r = confstr(_CS_POSIX_V7_ILP32_OFF32_CFLAGS, buf, sizeof(buf));
> + r = confstr(_CS_POSIX_V7_ILP32_OFFBIG_CFLAGS, buf, sizeof(buf));
> + r = confstr(_CS_POSIX_V7_LP64_OFF64_LIBS, buf, sizeof(buf));
> + r = confstr(_CS_POSIX_V6_LP64_OFF64_CFLAGS, buf, sizeof(buf));
> +static rtems_task Init(rtems_task_argument ignored)
> + rtems_test_run(ignored, TEST_STATE);
> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#include <rtems/confdefs.h>
> +/* end of file */
> diff --git a/testsuites/psxtests/psxconfstr/psxconfstr.doc b/testsuites/psxtests/psxconfstr/psxconfstr.doc
> index 0000000000..43501791b8
> --- /dev/null
> +++ b/testsuites/psxtests/psxconfstr/psxconfstr.doc
> @@ -0,0 +1,17 @@
> +# COPYRIGHT (c) 2020
> +# On-Line Applications Research Corporation (OAR).
> +# SPDX-License-Identifier: BSD-2-Clause
> +This file describes the directives and concepts tested by this test set.
> +test set name: psxconfstr
> +Directives:
> + Confstr()
> +Concepts:
> ++ This test exercises the confstr method
> diff --git a/testsuites/psxtests/psxconfstr/psxconfstr.scn b/testsuites/psxtests/psxconfstr/psxconfstr.scn
> index 0000000000..cb9e49dc72
> --- /dev/null
> +++ b/testsuites/psxtests/psxconfstr/psxconfstr.scn
> @@ -0,0 +1,4 @@
> +*** BEGIN OF TEST PSXCONFSTR ***
> +*** END OF TEST PSXCONFSTR ***
> 2.27.0
