[PATCH v4 0/2] Add MicroBlaze tools to RSB
Alex White
alex.white at oarcorp.com
Thu Aug 19 03:34:59 UTC 2021
Hi,
This patch set now depends on Joel's newlib hash bump and should be merged after
it.
v4:
- Rename to rtems-xilinx-gcc-10-newlib-head.cfg
- Simplify rtems-xilinx-gcc-10-newlib-head.cfg with include
v3:
- Follow naming convention for Xilinx .cfg files
- Simplify rtems-xilinx-binutils-2.36.cfg with rtems-binutils-2.36.cfg include
v2:
- Add Xilinx QEMU version to .cfg filename
- Exclude GDB configuration with unneeded Xilinx patches
This patch set adds the MicroBlaze tools to rtems-source-builder.
Thanks,
Alex
Alex White (2):
rsb: Add MicroBlaze tools
rsb: Add Xilinx QEMU
bare/config/devel/qemu-xilinx-v2020.2-1.cfg | 23 ++++++++++
bare/config/devel/qemu-xilinx.bset | 24 ++++++++++
rtems/config/6/rtems-microblaze.bset | 23 +++++++++-
.../tools/rtems-xilinx-binutils-2.36.cfg | 40 ++++++++++++++++
.../tools/rtems-xilinx-gcc-10-newlib-head.cfg | 46 +++++++++++++++++++
5 files changed, 155 insertions(+), 1 deletion(-)
create mode 100644 bare/config/devel/qemu-xilinx-v2020.2-1.cfg
create mode 100644 bare/config/devel/qemu-xilinx.bset
create mode 100644 rtems/config/tools/rtems-xilinx-binutils-2.36.cfg
create mode 100644 rtems/config/tools/rtems-xilinx-gcc-10-newlib-head.cfg
2.27.0
