[PATCH rtems] arm/xilinx: Fix zynq-uart interrupt receive
Chris Johns
chrisj at rtems.org
Wed Aug 18 18:20:40 UTC 2021
On 19/8/21 3:41 am, Kinsey Moore wrote:
> This is functional on the ZynqMP board I currently have setup for testing and on
> ZynqMP QEMU except for the data corruption/loss caused by the removal of the
> post-baud-set null write.
Thanks for the testing.
I am not sure if you are saying both the ZyncMP hardware and qemu need the write
or just qemu. The write may work but it does not make sense because at some
point the software will print a character and achive the same thing?
> Unrelated to this patch, I just realized that zynq_uart_set_attributes needs a
> call to zynq_uart_reset_tx_flush before adjusting any registers to avoid data
> loss there.
Ah OK, I will add this.
> One nit below.
> >> + while (ctx->tx_queued < 32 && len > 0) {
> Is 32 the size of the TX FIFO? It would be nice to see that as a sizeof() or a
> #define for better context.
The Versal is 32 bytes and the Zynq is 64 bytes. The Versal is based on the Arm
IP r1p5-00rel1 and the Zynq and ZynqMP is based on Cadence IP. We either accept
the lesser size on the Zynq and ZyncMP or the zynq_uart struct will need
specialised info from each variant of device sharing this code.
It looks like the UARTs are not fully compatible. The Versal's FIFO trigger
level reg is:
https://www.xilinx.com/html_docs/registers/am012/am012-versal-register-reference.html#uart___fifo_level.html
so it needs the timeout. I will add back the timeout support and see what
happens on the Zynq vs the Versal.
