[PATCH rtems] arm/xilinx: Fix zynq-uart interrupt receive
Kinsey Moore kinsey.moore at oarcorp.com
Wed Aug 18 19:49:05 UTC 2021
On 8/18/2021 13:20, Chris Johns wrote:
> On 19/8/21 3:41 am, Kinsey Moore wrote:
>> This is functional on the ZynqMP board I currently have setup for testing and on
>> ZynqMP QEMU except for the data corruption/loss caused by the removal of the
>> post-baud-set null write.
> Thanks for the testing.
> I am not sure if you are saying both the ZyncMP hardware and qemu need the write
> or just qemu. The write may work but it does not make sense because at some
> point the software will print a character and achive the same thing?
QEMU works fine either way. The ZynqMP hardware is what has issues
without the null write.
The problem is that it's picky about which characters will actually fix
the data loss/corruption.
I've seen that both space and null will do it while letters and numbers
won't. Null was chosen
specifically because it's not printable. Without this null print, I see
garbage output and it
eventually starts printing text correctly.
>> One nit below.
>>>> +    while (ctx->tx_queued < 32 && len > 0) {
>> Is 32 the size of the TX FIFO? It would be nice to see that as a sizeof() or a
>> #define for better context.
> The Versal is 32 bytes and the Zynq is 64 bytes. The Versal is based on the Arm
> IP r1p5-00rel1 and the Zynq and ZynqMP is based on Cadence IP. We either accept
> the lesser size on the Zynq and ZyncMP or the zynq_uart struct will need
> specialised info from each variant of device sharing this code.
I'm fine using 32 bytes across the board(s).
> It looks like the UARTs are not fully compatible. The Versal's FIFO trigger
> level reg is:
> https://www.xilinx.com/html_docs/registers/am012/am012-versal-register-reference.html#uart___fifo_level.html
> so it needs the timeout. I will add back the timeout support and see what
> happens on the Zynq vs the Versal.
Sounds good.
Kinsey
