[PATCH rtems v1 2/2] bsps/zynqmp: Added I2C support for ZynqMP
Stephen Clark stephen.clark at oarcorp.com
Tue Aug 24 14:05:51 UTC 2021
Chris,
This approach was also used in bsps/arm/xilinx-zynq/include/bsp/i2c.h. I kept it specifically for consistency; I assumed it was the standard approach, but your response makes me think it's not.
Is there a case to be made for breaking the register functions in both i2c.h files out into their own c files?
Thanks,
Stephen
> -----Original Message-----
> From: Chris Johns <chrisj at rtems.org>
> Sent: Monday, August 23, 2021 9:38 PM
> To: Stephen Clark <stephen.clark at oarcorp.com>; devel at rtems.org
> Subject: Re: [PATCH rtems v1 2/2] bsps/zynqmp: Added I2C support for ZynqMP
> On 24/8/21 8:24 am, Stephen Clark wrote:
> > Added I2C drivers for ZynqMP and updated build system accordingly.
> >  bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  4 ++
> >  bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h  | 63
> > +++++++++++++++++++  bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h  |  2 +
> >  bsps/aarch64/xilinx-zynqmp/start/bspstart.c   | 10 +++
> >  spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml |  4 ++
> > .../bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml  |  2 +
> >  .../aarch64/xilinx-zynqmp/objcadencei2c.yml   | 19 ++++++
> >  .../bsps/aarch64/xilinx-zynqmp/optclki2c0.yml | 19 ++++++
> > .../bsps/aarch64/xilinx-zynqmp/optclki2c1.yml | 19 ++++++
> >  9 files changed, 142 insertions(+)
> >  create mode 100644 bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h
> >  create mode 100644
> > spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml
> >  create mode 100644
> > spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c0.yml
> >  create mode 100644
> > spec/build/bsps/aarch64/xilinx-zynqmp/optclki2c1.yml
> > diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > index 83f2e2f4e4..6d49b9ad2a 100644
> > --- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > +++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > @@ -70,6 +70,10 @@ BSP_START_TEXT_SECTION void
> > zynqmp_setup_mmu_and_cache(void);
> >  void zynqmp_debug_console_flush(void);
> > +uint32_t zynqmp_clock_i2c0(void);
> > +uint32_t zynqmp_clock_i2c1(void);
> >  #ifdef __cplusplus
> >  #endif /* __cplusplus */
> > diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h
> > b/bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h
> > new file mode 100644
> > index 0000000000..e09747d414
> > --- /dev/null
> > +++ b/bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h
> > @@ -0,0 +1,63 @@
> > + * SPDX-License-Identifier: BSD-2-Clause
> > + * Copyright (C) 2021 On-Line Applications Research (OAR)
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in the
> > + *    documentation and/or other materials provided with the distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
> CONTRIBUTORS "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> LIMITED
> > +TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR
> > +PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> > +CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
> > +OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
> PROCUREMENT
> > +OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> > +BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> > +WHETHER IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> > +OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> > +ADVISED OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifndef LIBBSP_ARM_XILINX_ZYNQ_I2C_H
> > +#define LIBBSP_ARM_XILINX_ZYNQ_I2C_H
> > +#include <dev/i2c/cadence-i2c.h>
> > +#include <bsp/irq.h>
> > +#include <bsp.h>
> > +#ifdef __cplusplus
> > +extern "C" {
> > +#endif /* __cplusplus */
> > +static inline int zynqmp_register_i2c_0(void) {
> > +  return i2c_bus_register_cadence(
> > +    "/dev/i2c-0",
> > +    0x00FF020000,
> > +    zynqmp_clock_i2c0(),
> > +    ZYNQMP_IRQ_I2C_0
> > +static inline int zynqmp_register_i2c_1(void) {
> > +    "/dev/i2c-1",
> > +    0x00FF030000,
> > +    zynqmp_clock_i2c1(),
> > +    ZYNQMP_IRQ_I2C_1
> I know these are currently inlined but I do not know why they are. It is the only
> BSP that does this. Should they be moved to a .c file seem they are being
> touched?
> Chris
