[PATCH rtems v1 2/2] bsps/zynqmp: Added I2C support for ZynqMP
Tue Aug 24 22:41:17 UTC 2021
On 25/8/21 12:05 am, Stephen Clark wrote:
> This approach was also used in bsps/arm/xilinx-zynq/include/bsp/i2c.h. I kept it specifically for consistency; I assumed it was the standard approach, but your response makes me think it's not.
I am also not sure and why I asked :)
> Is there a case to be made for breaking the register functions in both i2c.h files out into their own c files?
I do not know. There can be a tendency to place things into line functions that
do not need to be. It saves work by not need to touch the build system. If the
code is being moved should it be moved to a C file? This is the reason I raised
this. I am happy to follow what ever Joel thinks.
