[PATCH v2] tester: Add MicroBlaze KCU105 QEMU BSP
Alex White
alex.white at oarcorp.com
Thu Aug 26 02:44:53 UTC 2021
tester/rtems/testing/bsps/kcu105_qemu.ini | 38 +++++++++++++++++++++++
tester/rtems/testing/qemu.cfg | 2 +-
2 files changed, 39 insertions(+), 1 deletion(-)
create mode 100644 tester/rtems/testing/bsps/kcu105_qemu.ini
diff --git a/tester/rtems/testing/bsps/kcu105_qemu.ini b/tester/rtems/testing/bsps/kcu105_qemu.ini
new file mode 100644
index 0000000..f61a3e3
--- /dev/null
+++ b/tester/rtems/testing/bsps/kcu105_qemu.ini
@@ -0,0 +1,38 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2021 On-Line Applications Research Corporation (OAR).
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The MicroBlaze KCU105 QEMU BSP.
+[kcu105_qemu]
+bsp = kcu105_qemu
+arch = microblazeel
+tester = %{_rtscripts}/qemu.cfg
+bsp_qemu_opts = %{qemu_opts_base} -M microblaze-fdt-plnx -m 256 -serial mon:stdio -display none
diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/qemu.cfg
index efaef8d..ad14cdb 100644
--- a/tester/rtems/testing/qemu.cfg
+++ b/tester/rtems/testing/qemu.cfg
@@ -82,4 +82,4 @@
# Executable
-%execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
+%execute %{qemu_cmd} %{qemu_opts} %{bsp_qemu_extra_opts} -kernel %{test_executable}
2.27.0
