[PATCH v2] tester: Add MicroBlaze KCU105 QEMU BSP
Chris Johns
chrisj at rtems.org
Thu Aug 26 05:52:09 UTC 2021
Hi Alex,
OK to push and thanks
On 26/8/21 12:44 pm, Alex White wrote:
> tester/rtems/testing/bsps/kcu105_qemu.ini | 38 +++++++++++++++++++++++
> tester/rtems/testing/qemu.cfg | 2 +-
> 2 files changed, 39 insertions(+), 1 deletion(-)
> create mode 100644 tester/rtems/testing/bsps/kcu105_qemu.ini
> diff --git a/tester/rtems/testing/bsps/kcu105_qemu.ini b/tester/rtems/testing/bsps/kcu105_qemu.ini
> new file mode 100644
> index 0000000..f61a3e3
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/kcu105_qemu.ini
> @@ -0,0 +1,38 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2021 On-Line Applications Research Corporation (OAR).
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# The MicroBlaze KCU105 QEMU BSP.
> +[kcu105_qemu]
> +bsp = kcu105_qemu
> +arch = microblazeel
> +tester = %{_rtscripts}/qemu.cfg
> +bsp_qemu_opts = %{qemu_opts_base} -M microblaze-fdt-plnx -m 256 -serial mon:stdio -display none
> diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/qemu.cfg
> index efaef8d..ad14cdb 100644
> --- a/tester/rtems/testing/qemu.cfg
> +++ b/tester/rtems/testing/qemu.cfg
> @@ -82,4 +82,4 @@
> # Executable
> -%execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
> +%execute %{qemu_cmd} %{qemu_opts} %{bsp_qemu_extra_opts} -kernel %{test_executable}
