[PATCH] score: Document Futex Handler
Sebastian Huber
Tue Aug 31 12:31:25 UTC 2021
Use EAGIN instead of EWOULDBLOCK to be in line with the Linux man page.
These error numbers have the same values in Newlib.
cpukit/score/src/futex.c | 42 ++++++++++++++++++++++++++++++++++++++--
1 file changed, 40 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/src/futex.c b/cpukit/score/src/futex.c
index b65a843704..f3a1ae3994 100644
--- a/cpukit/score/src/futex.c
+++ b/cpukit/score/src/futex.c
@@ -1,11 +1,12 @@
* @file
- * @ingroup RTEMSScore
+ * @ingroup RTEMSScoreFutex
* @brief This source file contains the implementation of
* _Futex_Wait() and _Futex_Wake().
* Copyright (c) 2015, 2016 embedded brains GmbH. All rights reserved.
@@ -20,6 +21,18 @@
* http://www.rtems.org/license/LICENSE.
+ * @defgroup RTEMSScoreFutex Futex Handler
+ * @brief This group contains the Futex Handler implementation.
+ * The behaviour of the futex operations is defined by Linux, see also:
+ * https://man7.org/linux/man-pages/man2/futex.2.html
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
@@ -84,6 +97,22 @@ static void _Futex_Queue_release(
_ISR_Local_enable( level );
+ * @brief Performs the ``FUTEX_WAIT`` operation.
+ * @param[in, out] _futex is the futex object.
+ * @param[in] uaddr is the address to the futex state.
+ * @param val is the expected futex state value.
+ * @retval 0 Returns zero if the futex state is equal to the expected value.
+ * In this case the calling thread is enqueued on the thread queue of the
+ * futex object.
+ * @retval EAGAIN Returns EAGAIN if the futex state is not equal to the
+ * expected value.
int _Futex_Wait( struct _Futex_Control *_futex, int *uaddr, int val )
Futex_Control *futex;
@@ -113,7 +142,7 @@ int _Futex_Wait( struct _Futex_Control *_futex, int *uaddr, int val )
eno = 0;
} else {
_Futex_Queue_release( futex, level, &queue_context );
- eno = EWOULDBLOCK;
+ eno = EAGAIN;
return eno;
@@ -143,6 +172,15 @@ static Thread_Control *_Futex_Flush_filter(
return the_thread;
+ * @brief Performs the ``FUTEX_WAKE`` operation.
+ * @param[in, out] _futex is the futex.
+ * @param count is the maximum count of threads to wake up.
+ * @return Returns the count of woken up threads.
int _Futex_Wake( struct _Futex_Control *_futex, int count )
2.31.1
