[PATCH] score: Document Futex Handler
Joel Sherrill
joel at rtems.org
Tue Aug 31 20:31:45 UTC 2021
On Tue, Aug 31, 2021, 7:31 AM Sebastian Huber <
> Use EAGIN instead of EWOULDBLOCK to be in line with the Linux man page.
EAGAIN AND Linux man page for what?
These error numbers have the same values in Newlib.
> cpukit/score/src/futex.c | 42 ++++++++++++++++++++++++++++++++++++++--
> 1 file changed, 40 insertions(+), 2 deletions(-)
> diff --git a/cpukit/score/src/futex.c b/cpukit/score/src/futex.c
> index b65a843704..f3a1ae3994 100644
> --- a/cpukit/score/src/futex.c
> +++ b/cpukit/score/src/futex.c
> @@ -1,11 +1,12 @@
> * @file
> - * @ingroup RTEMSScore
> + * @ingroup RTEMSScoreFutex
> * @brief This source file contains the implementation of
> * _Futex_Wait() and _Futex_Wake().
> * Copyright (c) 2015, 2016 embedded brains GmbH. All rights reserved.
> @@ -20,6 +21,18 @@
> * http://www.rtems.org/license/LICENSE.
> + * @defgroup RTEMSScoreFutex Futex Handler
> + * @brief This group contains the Futex Handler implementation.
> + * The behaviour of the futex operations is defined by Linux, see also:
> + * https://man7.org/linux/man-pages/man2/futex.2.html
> #ifdef HAVE_CONFIG_H
> #include "config.h"
> #endif
> @@ -84,6 +97,22 @@ static void _Futex_Queue_release(
> _ISR_Local_enable( level );
> + * @brief Performs the ``FUTEX_WAIT`` operation.
> + * @param[in, out] _futex is the futex object.
> + * @param[in] uaddr is the address to the futex state.
> + * @param val is the expected futex state value.
> + * @retval 0 Returns zero if the futex state is equal to the expected
> value.
> + * In this case the calling thread is enqueued on the thread queue of
> the
> + * futex object.
> + * @retval EAGAIN Returns EAGAIN if the futex state is not equal to the
> + * expected value.
> int _Futex_Wait( struct _Futex_Control *_futex, int *uaddr, int val )
> Futex_Control *futex;
> @@ -113,7 +142,7 @@ int _Futex_Wait( struct _Futex_Control *_futex, int
> *uaddr, int val )
> eno = 0;
> } else {
> _Futex_Queue_release( futex, level, &queue_context );
> - eno = EWOULDBLOCK;
> + eno = EAGAIN;
> return eno;
> @@ -143,6 +172,15 @@ static Thread_Control *_Futex_Flush_filter(
> return the_thread;
> + * @brief Performs the ``FUTEX_WAKE`` operation.
> + * @param[in, out] _futex is the futex.
> + * @param count is the maximum count of threads to wake up.
> + * @return Returns the count of woken up threads.
> int _Futex_Wake( struct _Futex_Control *_futex, int count )
> 2.31.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210831/a23bef45/attachment-0001.html>
