[PATCH v1 2/5] cpukit: Add Exception Manager
Kinsey Moore kinsey.moore at oarcorp.com
Tue Aug 31 13:35:21 UTC 2021
On 8/31/2021 04:31, Sebastian Huber wrote:
> On 30/08/2021 17:13, Kinsey Moore wrote:
>> On 8/30/2021 07:50, Sebastian Huber wrote:
>>> On 30/08/2021 14:27, Kinsey Moore wrote:
>>>> On 8/30/2021 00:42, Sebastian Huber wrote:
>>>>> Hello Kinsey,
>>>>> why can't you use the existing fatal error extension for this? You
>>>>> just have to test for an RTEMS_FATAL_SOURCE_EXTENSION source.  The
>>>>> fatal code is a pointer to the exception frame.
>>>> Unfortunately, the fatal error extensions framework necessarily
>>>> assumes that the exception is fatal and so does not include the
>>>> machinery to perform a thread dispatch or restore the exception
>>>> frame for additional execution. It could theoretically be done in
>>>> the fatal error extensions context, but it would end up being
>>>> reimplemented for every architecture and you'd have to unwind the
>>>> stack manually. I'm sure there are other ragged edges that would
>>>> have to be smoothed over as well.
>>> Non-interrupt exceptions are not uniformly handled across
>>> architectures in RTEMS currently. Adding the
>>> RTEMS_FATAL_SOURCE_EXTENSION fatal source was an attempt to do this.
>>> I am not that fond of adding a second approach unless there are
>>> strong technical reasons to do this.
>> This was in an effort to formalize how recoverable exceptions are
>> handled. Currently, it's done on on SPARC by handling exception traps
>> as you would an interrupt trap since they share a common architecture
>> on that platform. This representation varies quite a bit among
>> platforms, so we needed a different mechanism.
> I recently changed the non-interrupt exception handling on sparc,
> since it was not robust against a corrupt stack pointer:
> http://devel.rtems.org/ticket/4459
>>> The initial fatal extensions are quite robust, you only need a
>>> stack, valid read-only data and a valid code. So, using a user
>>> extension is the right thing to do, but I don't thing we need a new
>>> one.
>>> Doing the non-interrupt exception processing on the stack which
>>> caused the exception is a bit problematic, since the stack pointer
>>> might be corrupt as well. It is more robust to switch to for example
>>> the interrupt stack. If the exception was caused by an interrupt,
>>> then this exception is not recoverable.
>> The non-interrupt exception processing occurs on the interrupt stack,
>> not the thread/user stack. In the AArch64 support code provided, the
>> stack is switched back to the thread/user stack before thread
>> dispatch and exception frame restoration occurs.
> You can only switch back to the thread stack if it is valid. Doing a
> thread dispatch should be only done if you are sure that the system
> state is still intact. This is probably no the case for most exceptions.
If the handler has declared that it handled the exception and corrected
the cause underlying the exception then the system state should be
valid. If it can't make that claim then it should not have handled the
exception.
>>> If the non-interrupt exception was caused by a thread, then you
>>> could do some high level actions for some exceptions, such as
>>> floating-point exceptions and arithmetic exceptions. If you get a
>>> data abort or instruction error, then it is probably better to
>>> terminate the system.
>> I leave that decision to the handlers defined on this framework. In
>> the case of the exception-to-signal mapping, I'm carrying over the
>> existing exception set from the SPARC implementation.
> It is probably this code:
> +    case EXCEPTION_DATA_ABORT_READ:
> +    case EXCEPTION_DATA_ABORT_WRITE:
> +    case EXCEPTION_DATA_ABORT_UNSPECIFIED:
> +    case EXCEPTION_INSTRUCTION_ABORT:
> +    case EXCEPTION_MMU_UNSPECIFIED:
> +    case EXCEPTION_ACCESS_ALIGNMENT:
> +      signal = SIGSEGV;
> +      break;
> +    default:
> +       * Covers unknown, PC/SP alignment, illegal execution state,
> and any new
> +       * exception classes that get added.
> +      signal = SIGILL;
> +      break;
> Using signals to handle these exceptions is like playing Russian
> roulette.
You're right. Specifically, SP alignment faults should be moved to the
not-handled section because they're not actually handled here and would
have to be to proceed with further execution. I'll make that change, thanks.
>>> Non-interrupt exception handling is always architecture-dependent.
>>> It is just a matter how you organize it. In general, the most
>>> sensible way to deal with non-interrupt exceptions is to log the
>>> error somehow and terminate the system. The mapping to signals is a
>>> bit of a special case if you ask me. My preferred way to handle
>>> non-interrupt exceptions would be to
>>> 1. switch to a dedicated stack
>>> 2. save the complete register set to the CPU exception frame
>>> 3. call the fatal error extensions with RTEMS_FATAL_SOURCE_EXTENSION
>>> and the CPU exception frame (with interrupts disabled)
>>> Add a new API to query/alter the CPU exception frame, switch to the
>>> stack indicated by the CPU exception frame, and restore the context
>>> stored in the CPU exception frame. With these architecture-dependent
>>> CPU exception frame support it should be possible to implement a
>>> high level mapper to signals.
>> What you've described is basically what is happening here (the
>> dedicated stack is currently the interrupt/exception stack on
>> AArch64), but the low level details are necessarily contained within
>> the CPU port in patch 3/5. Support for this framework is not required
>> for any CPU port, but CPU ports that do support it repurpose the
>> existing code underlying the fatal error extensions with the
>> additional support you described above.
> I don't think that looking at existing code is the right thing to do.
> The exception handling is too diverse in RTEMS. We should think about
> how a clean design should look like.
I repurposed the existing code in the AArch64 CPU port because it
happened to do part of what was needed as you listed just above. This
may not be a perfectly clean design, but it's cleaner than what
currently exists for recoverably handling machine exceptions. What
currently exists is: hooking the exception vector(s) with one-off
assembly for each platform and exception type.
>> This does not exist in parallel to the fatal error extensions, but
>> rather the fatal error extensions are moved on top of the Exception
>> Manager for CPU ports that support it. The Exception Manager returns
>> whether the exception was handled and the CPU port then calls the
>> fatal error extensions if the exception wasn't handled. With this
>> patch set, only an accessor was added to get the exception class, but
>> my initial thoughts included manipulation of the execution address
>> and several other more generic manipulators.
> If a non-interrupt exception occurs, the default behaviour should be
> to terminate the system as robust and save as possible. Raising signal
> should be optional and not make the exception handling less robust.
> The support for the signals should also not lead to dead code in the
> default case. This is why I proposed a two step approach. The first
> step is a normal fatal error handler. The second step is a resume of
> normal multitasking in a special signal fatal error extension using an
> architecture-specific "jump" which is defined by the CPU exception frame.
I don't think I understand how a signal could be sent to the runtime
while simultaneously shutting down the system since system shutdown
would necessarily occur before the signal could be sent in thread dispatch.
As things are currently setup, the signal mapping hook is only installed
if the application specifically requests it and is off by default. The
average application will see no change to exception handling since it
does not request the mapping and there are no default recoverable
exception handlers.
If fatal error handlers run first, assumptions are made that violate the
ability to resume processing because they are specifically fatal handlers.
Kinsey
