[PATCH v1 2/5] cpukit: Add Exception Manager
Tue Aug 31 22:50:06 UTC 2021
On 31/8/21 11:35 pm, Kinsey Moore wrote:
> On 8/31/2021 04:31, Sebastian Huber wrote:
>> On 30/08/2021 17:13, Kinsey Moore wrote:
>>> On 8/30/2021 07:50, Sebastian Huber wrote:
>>>> On 30/08/2021 14:27, Kinsey Moore wrote:
>>>>> On 8/30/2021 00:42, Sebastian Huber wrote:
>>>>>> Hello Kinsey,
>>>>>> why can't you use the existing fatal error extension for this? You just
>>>>>> have to test for an RTEMS_FATAL_SOURCE_EXTENSION source.  The fatal code
>>>>>> is a pointer to the exception frame.
>>>>> Unfortunately, the fatal error extensions framework necessarily assumes
>>>>> that the exception is fatal and so does not include the machinery to
>>>>> perform a thread dispatch or restore the exception frame for additional
>>>>> execution. It could theoretically be done in the fatal error extensions
>>>>> context, but it would end up being reimplemented for every architecture and
>>>>> you'd have to unwind the stack manually. I'm sure there are other ragged
>>>>> edges that would have to be smoothed over as well.
>>>> Non-interrupt exceptions are not uniformly handled across architectures in
>>>> RTEMS currently. Adding the RTEMS_FATAL_SOURCE_EXTENSION fatal source was an
>>>> attempt to do this. I am not that fond of adding a second approach unless
>>>> there are strong technical reasons to do this.
>>> This was in an effort to formalize how recoverable exceptions are handled.
>>> Currently, it's done on on SPARC by handling exception traps as you would an
>>> interrupt trap since they share a common architecture on that platform. This
>>> representation varies quite a bit among platforms, so we needed a different
>>> mechanism.
>> I recently changed the non-interrupt exception handling on sparc, since it was
>> not robust against a corrupt stack pointer:
>> http://devel.rtems.org/ticket/4459
>>>> The initial fatal extensions are quite robust, you only need a stack, valid
>>>> read-only data and a valid code. So, using a user extension is the right
>>>> thing to do, but I don't thing we need a new one.
>>>> Doing the non-interrupt exception processing on the stack which caused the
>>>> exception is a bit problematic, since the stack pointer might be corrupt as
>>>> well. It is more robust to switch to for example the interrupt stack. If the
>>>> exception was caused by an interrupt, then this exception is not recoverable.
>>> The non-interrupt exception processing occurs on the interrupt stack, not the
>>> thread/user stack. In the AArch64 support code provided, the stack is
>>> switched back to the thread/user stack before thread dispatch and exception
>>> frame restoration occurs.
>> You can only switch back to the thread stack if it is valid. Doing a thread
>> dispatch should be only done if you are sure that the system state is still
>> intact. This is probably no the case for most exceptions.
> If the handler has declared that it handled the exception and corrected the
> cause underlying the exception then the system state should be valid. If it
> can't make that claim then it should not have handled the exception.
There are valid use cases for this such as an unhandled fault in a task
suspending it. Till did this for EPICS years ago.
Our job is to provide the support to implement system level requirements and we
should leave the analysis and discussions about being valid to our users.
Libdebugger is a good example of a system that handles faults of all types and
RTEMS keeps running without an issue.
>>>> If the non-interrupt exception was caused by a thread, then you could do
>>>> some high level actions for some exceptions, such as floating-point
>>>> exceptions and arithmetic exceptions. If you get a data abort or instruction
>>>> error, then it is probably better to terminate the system.
>>> I leave that decision to the handlers defined on this framework. In the case
>>> of the exception-to-signal mapping, I'm carrying over the existing exception
>>> set from the SPARC implementation.
>> It is probably this code:
>> +    case EXCEPTION_DATA_ABORT_READ:
>> +    case EXCEPTION_DATA_ABORT_WRITE:
>> +    case EXCEPTION_DATA_ABORT_UNSPECIFIED:
>> +    case EXCEPTION_INSTRUCTION_ABORT:
>> +    case EXCEPTION_MMU_UNSPECIFIED:
>> +    case EXCEPTION_ACCESS_ALIGNMENT:
>> +      signal = SIGSEGV;
>> +      break;
>> +    default:
>> +       * Covers unknown, PC/SP alignment, illegal execution state, and any new
>> +       * exception classes that get added.
>> +      signal = SIGILL;
>> +      break;
>> Using signals to handle these exceptions is like playing Russian roulette.
> You're right. Specifically, SP alignment faults should be moved to the
> not-handled section because they're not actually handled here and would have to
> be to proceed with further execution. I'll make that change, thanks.
>>>>> Non-interrupt exception handling is always architecture-dependent. It is
>>>> just a matter how you organize it. In general, the most sensible way to deal
>>>> with non-interrupt exceptions is to log the error somehow and terminate the
>>>> system. The mapping to signals is a bit of a special case if you ask me. My
>>>> preferred way to handle non-interrupt exceptions would be to
>>>> 1. switch to a dedicated stack
>>>> 2. save the complete register set to the CPU exception frame
>>>> 3. call the fatal error extensions with RTEMS_FATAL_SOURCE_EXTENSION and the
>>>> CPU exception frame (with interrupts disabled)
>>>> Add a new API to query/alter the CPU exception frame, switch to the stack
>>>> indicated by the CPU exception frame, and restore the context stored in the
>>>> CPU exception frame. With these architecture-dependent CPU exception frame
>>>> support it should be possible to implement a high level mapper to signals.
>>> What you've described is basically what is happening here (the dedicated
>>> stack is currently the interrupt/exception stack on AArch64), but the low
>>> level details are necessarily contained within the CPU port in patch 3/5.
>>> Support for this framework is not required for any CPU port, but CPU ports
>>> that do support it repurpose the existing code underlying the fatal error
>>> extensions with the additional support you described above.
>> I don't think that looking at existing code is the right thing to do. The
>> exception handling is too diverse in RTEMS. We should think about how a clean
>> design should look like.
> I repurposed the existing code in the AArch64 CPU port because it happened to do
> part of what was needed as you listed just above. This may not be a perfectly
> clean design, but it's cleaner than what currently exists for recoverably
> handling machine exceptions. What currently exists is: hooking the exception
> vector(s) with one-off assembly for each platform and exception type.
Yes it is a low level interface. My concern is creating a piece meal outcome, a
sort of we have done what we need and other will need to do the same.
>> This does not exist in parallel to the fatal error extensions, but rather the
>>> fatal error extensions are moved on top of the Exception Manager for CPU
>>> ports that support it. The Exception Manager returns whether the exception
>>> was handled and the CPU port then calls the fatal error extensions if the
>>> exception wasn't handled. With this patch set, only an accessor was added to
>>> get the exception class, but my initial thoughts included manipulation of the
>>> execution address and several other more generic manipulators.
>> If a non-interrupt exception occurs, the default behaviour should be to
>> terminate the system as robust and save as possible. Raising signal should be
>> optional and not make the exception handling less robust.
Agreed.
Also enabling signals anywhere is an issue if libbsd is used as it does not
support them. Doing so would create hard to find holes in a complex system.
>> The support for the
>> signals should also not lead to dead code in the default case. This is why I
>> proposed a two step approach. The first step is a normal fatal error handler.
>> The second step is a resume of normal multitasking in a special signal fatal
>> error extension using an architecture-specific "jump" which is defined by the
I support this approach. I see this as basically bringing parts of the
libdebugger back end into score/cpu and I welcome that.
I suggest the ARM architecture be considered first because it is the hardest. If
you can solve this one I suspect we will have a suitable interface and
structure. The ARM is complex because of the mix of exceptions, the various mix
of control registers, the exception space verses the task space and finally ARM
and thumb modes.
> I don't think I understand how a signal could be sent to the runtime while
> simultaneously shutting down the system since system shutdown would necessarily
> occur before the signal could be sent in thread dispatch.
My understanding is the shutdown would be default outcome for any exception, ie
what we have now. If you catch those exceptions, transition back to the thread
arena and raise a signal there would be no shutdown.
> As things are currently setup, the signal mapping hook is only installed if the
> application specifically requests it and is off by default. The average
> application will see no change to exception handling since it does not request
> the mapping and there are no default recoverable exception handlers.
Where does this leave libdebugger? Have you tested the integration of this
signal functionality with libdebugger?
In which context does a signal handler run? Is it like an ASR or is it running
in the context of the exception?
