[PATCH rtems-tools 6/8] TraceConverter.cc: Convert to C++
Ryan Long
ryan.long at oarcorp.com
Fri Dec 3 14:47:57 UTC 2021
tester/covoar/TraceConverter.cc | 35 +++++++++++++++++------------------
1 file changed, 17 insertions(+), 18 deletions(-)
diff --git a/tester/covoar/TraceConverter.cc b/tester/covoar/TraceConverter.cc
index 4c62b06..1a03b49 100644
--- a/tester/covoar/TraceConverter.cc
+++ b/tester/covoar/TraceConverter.cc
@@ -27,15 +27,14 @@
#define kill(p,s) raise(s)
#endif
-char* progname;
+std::string progname;
void usage()
- fprintf(
- stderr,
- "Usage: %s [-v] -c CPU -e executable -t tracefile [-E logfile]\n",
- progname
+ std::cerr << "Usage: "
+ << progname
+ << " [-v] -c CPU -e executable -t tracefile [-E logfile]"
+ << std::endl;
exit(1);
@@ -81,10 +80,10 @@ int main(
int opt;
Trace::TraceReaderLogQEMU log;
Trace::TraceWriterQEMU trace;
- const char *cpuname = "";
- const char *executable = "";
- const char *tracefile = "";
- const char *logname = "/tmp/qemu.log";
+ std::string cpuname;
+ std::string executable;
+ std::string tracefile;
+ std::string logname = "/tmp/qemu.log";
Coverage::ExecutableInfo* executableInfo;
rld::process::tempfile objdumpFile( ".dmp" );
rld::process::tempfile err( ".err" );
@@ -114,18 +113,18 @@ int main(
// Make sure we have all the required parameters
- if ( !cpuname ) {
- fprintf( stderr, "cpuname not specified\n" );
+ if ( cpuname.empty() ) {
+ std::cerr << "cpuname not specified" << std::endl;
usage();
- if ( !executable ) {
- fprintf( stderr, "executable not specified\n" );
+ if ( executable.empty() ) {
+ std::cerr << "executable not specified" << std::endl;
usage();
- if ( !tracefile ) {
- fprintf( stderr, "output trace file not specified\n" );
+ if ( tracefile.empty() ) {
+ std::cerr << "output trace file not specified" << std::endl;
usage();
@@ -195,8 +194,8 @@ int main(
try
objdumpProcessor.loadAddressTable( executableInfo, objdumpFile, err );
- log.processFile( logname, objdumpProcessor );
- trace.writeFile( tracefile, &log, verbose );
+ log.processFile( logname.c_str(), objdumpProcessor );
+ trace.writeFile( tracefile.c_str(), &log, verbose );
catch ( rld::error re )
1.8.3.1
