[PATCH rtems-tools 7/8] TraceConverter.cc: Fix formatting
Ryan Long
ryan.long at oarcorp.com
Fri Dec 3 14:47:58 UTC 2021
tester/covoar/TraceConverter.cc | 40 +++++++++++++++++++++-------------------
1 file changed, 21 insertions(+), 19 deletions(-)
diff --git a/tester/covoar/TraceConverter.cc b/tester/covoar/TraceConverter.cc
index 1a03b49..b5dc20c 100644
--- a/tester/covoar/TraceConverter.cc
+++ b/tester/covoar/TraceConverter.cc
@@ -35,11 +35,10 @@ void usage()
<< progname
<< " [-v] -c CPU -e executable -t tracefile [-E logfile]"
<< std::endl;
- exit(1);
+ exit( 1 );
-static void
-fatal_signal( int signum )
+static void fatal_signal( int signum )
signal( signum, SIG_DFL );
@@ -52,20 +51,23 @@ fatal_signal( int signum )
kill( getpid(), signum );
-static void
-setup_signals( void )
+static void setup_signals()
- if ( signal (SIGINT, SIG_IGN) != SIG_IGN )
+ if ( signal (SIGINT, SIG_IGN) != SIG_IGN ) {
signal( SIGINT, fatal_signal );
#ifdef SIGHUP
- if ( signal( SIGHUP, SIG_IGN ) != SIG_IGN )
+ if ( signal( SIGHUP, SIG_IGN ) != SIG_IGN ) {
signal( SIGHUP, fatal_signal );
#endif
- if ( signal( SIGTERM, SIG_IGN ) != SIG_IGN )
+ if ( signal( SIGTERM, SIG_IGN ) != SIG_IGN ) {
signal( SIGTERM, fatal_signal );
#ifdef SIGPIPE
- if ( signal( SIGPIPE, SIG_IGN ) != SIG_IGN )
+ if ( signal( SIGPIPE, SIG_IGN ) != SIG_IGN ) {
signal( SIGPIPE, fatal_signal );
#endif
#ifdef SIGCHLD
signal( SIGCHLD, SIG_DFL );
@@ -100,15 +102,15 @@ int main(
progname = argv[0];
- while ((opt = getopt(argc, argv, "c:e:l:L:t:v")) != -1) {
- switch (opt) {
- case 'c': cpuname = optarg; break;
- case 'e': executable = optarg; break;
- case 'l': logname = optarg; break;
+ while ( (opt = getopt( argc, argv, "c:e:l:L:t:v" ) ) != -1 ) {
+ switch ( opt ) {
+ case 'c': cpuname = optarg; break;
+ case 'e': executable = optarg; break;
+ case 'l': logname = optarg; break;
case 'L': dynamicLibrary = optarg; break;
- case 't': tracefile = optarg; break;
- case 'v': verbose = true; break;
- default: usage();
+ case 't': tracefile = optarg; break;
+ case 'v': verbose = true; break;
+ default: usage();
@@ -146,14 +148,14 @@ int main(
Coverage::ObjdumpProcessor objdumpProcessor( symbolsToAnalyze, targetInfo );
- if ( !dynamicLibrary.empty() )
+ if ( !dynamicLibrary.empty() ) {
executableInfo = new Coverage::ExecutableInfo(
executable,
dynamicLibrary,
false,
symbolsToAnalyze
- else {
+ } else {
try
1.8.3.1
