[PATCH] untar: Make behavior similar to GNU or BSD tar
Joel Sherrill
joel at rtems.org
Fri Dec 3 17:34:08 UTC 2021
I don't see anything that would stop this from being committed.
This does make me realize that I think all of the untar capabilities
are undocumented.
--joel
On Fri, Dec 3, 2021 at 6:51 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> RTEMS untar implementation had problems with overwriting or integrating
> archives into existing directory structures. This patch adapts the
> behavior to mimic that of a GNU tar or BSD tar and extends the tar01
> test to check for the behavior. That is:
> * If a directory structure exists, the files from the archive will be
> integrated. Existing files are overwritten.
> * If a file exists and the archive contains a directory with the same
> name, the file is removed and a directory is created. In the above
> example: if l1/l2 is a file it will be overwritten with a new
> directory.
> * If a directory exists and the archive contains a file with the same
> name, the directory will be replaced if it is empty. If it contains
> files, the result is an error.
> * An archive also can contain only a file without the parent
> directories. If in that case one of the parent directories exists as a
> file extracting the archive results in an error. In the example: if
> l1/l2 is a file and the archive doesn't contain the directories but
> only the file l1/l2/x.txt that would be an error.
> * In case of an error, it is possible that the archive has been
> partially extracted.
> Closes #4552
> cpukit/libmisc/untar/untar.c | 57 +++++---
> testsuites/libtests/tar01/init.c | 199 +++++++++++++++++++++++++++-
> testsuites/libtests/tar01/tar01.doc | 1 +
> testsuites/libtests/tar01/tar01.scn | 54 ++++++--
> testsuites/libtests/tar01/tar01.tar | Bin 10240 -> 10240 bytes
> 5 files changed, 282 insertions(+), 29 deletions(-)
> diff --git a/cpukit/libmisc/untar/untar.c b/cpukit/libmisc/untar/untar.c
> index a2f09fb99f..8888ab2c57 100644
> --- a/cpukit/libmisc/untar/untar.c
> +++ b/cpukit/libmisc/untar/untar.c
> @@ -126,30 +126,25 @@ Make_Path(const rtems_printer *printer, char *path)
> *p = '\0';
> if (p[1] == '\0') {
> - /* Speculatively unlink the last component so that it can be re-created */
> - unlink(path);
> return 0;
> if (mkdir(path, S_IRWXU | S_IRWXG | S_IRWXO) != 0) {
> - if (errno == EEXIST || errno == EISDIR) {
> + if (errno == EEXIST) {
> + /* If it exists already: Check whether it is a directory */
> struct stat sb;
> - if (stat(path, &sb) != 0) {
> + if (lstat(path, &sb) != 0) {
> + Print_Error(printer, "lstat", path);
> + return -1;
> + } else if (!S_ISDIR(sb.st_mode)) {
> + rtems_printf(printer,
> + "untar: mkdir: %s: exists but is not a directory\n",
> + path);
> return -1;
> - if (!S_ISDIR(sb.st_mode)) {
> - if (unlink(path) != 0) {
> - Print_Error(printer, "unlink", path);
> - return -1;
> - if (mkdir(path, S_IRWXU | S_IRWXG | S_IRWXO) != 0) {
> - Print_Error(printer, "mkdir (unlink)", path);
> - return -1;
> + } else {
> + Print_Error(printer, "mkdir", path);
> + return -1;
> @@ -206,6 +201,12 @@ Untar_ProcessHeader(
> if (Make_Path(ctx->printer, ctx->file_path) != 0) {
> retval = UNTAR_FAIL;
> + } else {
> + * Speculatively unlink. This should unlink everything but non-empty
> + * directories or write protected stuff.
> + unlink(ctx->file_path);
> if (ctx->linkflag == SYMTYPE) {
> @@ -225,8 +226,22 @@ Untar_ProcessHeader(
> rtems_printf(ctx->printer, "untar: dir: %s\n", ctx->file_path);
> r = mkdir(ctx->file_path, ctx->mode);
> if (r != 0) {
> - Print_Error(ctx->printer, "mkdir", ctx->file_path);
> - retval = UNTAR_FAIL;
> + struct stat sb;
> + if (lstat(ctx->file_path, &sb) != 0) {
> + Print_Error(ctx->printer, "lstat", ctx->file_path);
> + retval = UNTAR_FAIL;
> + rtems_printf(ctx->printer,
> + ctx->file_path);
> + } else {
> + Print_Error(ctx->printer, "mkdir", ctx->file_path);
> @@ -426,7 +441,9 @@ Untar_FromFile_Print(
> if ((out_fd = creat(ctx.file_path, ctx.mode)) == -1) {
> - (void) lseek(fd, SEEK_CUR, 512UL * ctx.nblocks);
> + /* Couldn't create that file. Abort. */
> + break;
> } else {
> for (i = 0; i < ctx.nblocks; i++) {
> n = read(fd, bufr, 512);
> diff --git a/testsuites/libtests/tar01/init.c b/testsuites/libtests/tar01/init.c
> index 4cad67a6ae..2deff3a482 100644
> --- a/testsuites/libtests/tar01/init.c
> +++ b/testsuites/libtests/tar01/init.c
> @@ -7,6 +7,33 @@
> * http://www.rtems.org/license/LICENSE.
> + * Note on the used tar file: Generate the file on a system that supports
> + * symlinks with the following commands (tested on Linux - you might have to
> + * adapt on other systems):
> + * export WORK=some_work_directory
> + * rm -r ${WORK}
> + * mkdir -p ${WORK}/home/abc/def
> + * mkdir -p ${WORK}/home/dir
> + * cd ${WORK}
> + * echo "#! joel" > home/abc/def/test_script
> + * echo "ls -las /dev" >> home/abc/def/test_script
> + * chmod 755 home/abc/def/test_script
> + * echo "This is a test of loading an RTEMS filesystem from an" > home/test_file
> + * echo "initial tar image." >> home/test_file
> + * echo "Hello world" >> home/dir/file
> + * ln -s home/test_file symlink
> + * tar cf tar01.tar --format=ustar \
> + * symlink \
> + * home/test_file \
> + * home/abc/def/test_script \
> + * home/dir
> + * Note that "home/dir" is in the archive as separate directory. "home/abc" is
> + * only in the archive as a parent of the file "test_script".
> #ifdef HAVE_CONFIG_H
> #include "config.h"
> #endif
> @@ -95,6 +122,84 @@ void test_untar_from_memory(void)
> +static void assert_file_content(
> + const char *name,
> + const char *expected_content,
> + ssize_t expected_size
> + char buf[16];
> + int fd;
> + int rd;
> + fd = open(name, O_RDONLY);
> + rtems_test_assert( fd >= 0 );
> + do {
> + rd = read(fd, buf, sizeof(buf));
> + rtems_test_assert( rd >= 0 );
> + if (rd > 0) {
> + rtems_test_assert( expected_size - rd >= 0 );
> + rtems_test_assert( memcmp(buf, expected_content, rd) == 0 );
> + expected_content += rd;
> + expected_size -= rd;
> + } while(rd > 0);
> + rtems_test_assert( expected_size == 0 );
> + close(fd);
> +static void assert_content_like_expected(void)
> + const char *directories[] = {
> + "home",
> + "home/abc",
> + "home/abc/def",
> + "home/dir",
> + const char *symlinks[] = {
> + "symlink",
> + const struct {
> + const char *name;
> + const char *content;
> + } files[] = {
> + .name = "home/abc/def/test_script",
> + .content = "#! joel\nls -las /dev\n",
> + .name = "home/test_file",
> + .content = "This is a test of loading an RTEMS filesystem from an\n"
> + "initial tar image.\n",
> + .name = "home/dir/file",
> + .content = "Hello world\n",
> + size_t i;
> + struct stat st;
> + for(i = 0; i < RTEMS_ARRAY_SIZE(directories); ++i) {
> + lstat(directories[i], &st);
> + rtems_test_assert( S_ISDIR(st.st_mode) );
> + for(i = 0; i < RTEMS_ARRAY_SIZE(symlinks); ++i) {
> + lstat(symlinks[i], &st);
> + rtems_test_assert( S_ISLNK(st.st_mode) );
> + for(i = 0; i < RTEMS_ARRAY_SIZE(files); ++i) {
> + lstat(files[i].name, &st);
> + rtems_test_assert( S_ISREG(st.st_mode) );
> + assert_file_content(
> + files[i].name,
> + files[i].content,
> + strlen(files[i].content)
> void test_untar_from_file(void)
> int fd;
> @@ -119,13 +224,105 @@ void test_untar_from_file(void)
> rv = chdir( "/dest" );
> rtems_test_assert( rv == 0 );
> - /* Untar it */
> + /* Case 1: Untar it into empty directory */
> rv = Untar_FromFile( "/test.tar" );
> printf("Untaring from file - ");
> if (rv != UNTAR_SUCCESSFUL) {
> printf ("error: untar failed: %i\n", rv);
> exit(1);
> + assert_content_like_expected();
> + printf ("successful\n");
> + /* Case 2: Most files exist */
> + rv = unlink("/dest/home/test_file");
> + rtems_test_assert( rv == 0 );
> + rv = Untar_FromFile( "/test.tar" );
> + printf("Untar from file into existing structure with one missing file - ");
> + if (rv != UNTAR_SUCCESSFUL) {
> + printf ("error: untar failed: %i\n", rv);
> + exit(1);
> + /* Case 3: An empty directory exists where a file should be */
> + rv = mkdir("/dest/home/test_file", S_IRWXU | S_IRWXG | S_IROTH | S_IXOTH);
> + printf("Untar from file; overwrite empty directory with file - ");
> + exit(1);
> + /* Case 4: A file exists where a parent directory should be created */
> + rv = unlink("/dest/home/abc/def/test_script");
> + rv = unlink("/dest/home/abc/def");
> + rv = unlink("/dest/home/abc");
> + fd = creat("/dest/home/abc", S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH);
> + close(fd);
> + printf("Untar from file; file exists where parent dir should be created - ");
> + if (rv != UNTAR_FAIL) {
> + printf ("error: untar didn't fail like expected: %i\n", rv);
> + exit(1);
> + printf ("expected fail\n");
> + /* cleanup so that the next one works */
> + /* Case 5: A non-empty directory exists where a file should be created */
> + fd = creat("/dest/home/test_file/file",
> + S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH);
> + close(fd);
> + printf("Untar from file; non-empty dir where file should be created - ");
> + exit(1);
> + rv = unlink("/dest/home/test_file/file");
> + /* Case 6: A file exists where a directory is explicitly in the archive */
> + rv = unlink("/dest/home/dir/file");
> + rv = unlink("/dest/home/dir");
> + fd = creat("/dest/home/dir", S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH);
> + close(fd);
> + printf("Untar from file; overwrite file with explicit directory - ");
> + exit(1);
> diff --git a/testsuites/libtests/tar01/tar01.doc b/testsuites/libtests/tar01/tar01.doc
> index 060f98a813..adffdca291 100644
> --- a/testsuites/libtests/tar01/tar01.doc
> +++ b/testsuites/libtests/tar01/tar01.doc
> @@ -20,3 +20,4 @@ directives:
> concepts:
> + exercise these routines
> ++ check whether existing files are overwritten or not overwritten like expected
> diff --git a/testsuites/libtests/tar01/tar01.scn b/testsuites/libtests/tar01/tar01.scn
> index 68fa951881..dd72f9517b 100644
> --- a/testsuites/libtests/tar01/tar01.scn
> +++ b/testsuites/libtests/tar01/tar01.scn
> @@ -1,9 +1,24 @@
> -*** TAR01 TEST ***
> -Untaring from memory - successful
> +*** BEGIN OF TEST TAR 1 ***
> +*** TEST VERSION: 6.0.0.e1efb4eb8a9d6dd5f6f37dafc9feb0a9e6a888f1
> +*** TEST STATE: EXPECTED_PASS
> +*** TEST BUILD: RTEMS_POSIX_API
> +*** TEST TOOLS: 10.3.1 20210409 (RTEMS 6, RSB ad54d1dd3cf8249d9d39deb1dd28b2f294df062d-modified, Newlib eb03ac1)
> +Untaring from memory - untar: memory at 0x11ece8 (10240)
> +untar: symlink: home/test_file -> symlink
> +untar: file: home/test_file (s:73,m:0644)
> +untar: file: home/abc/def/test_script (s:21,m:0755)
> +untar: dir: home/dir
> +untar: file: home/dir/file (s:12,m:0644)
> +successful
> ========= /home/test_file =========
> (0)This is a test of loading an RTEMS filesystem from an
> initial tar image.
> +========= /home/abc/def/test_script =========
> +(0)#! joel
> +ls -las /dev
> + /home/abc/def/test_script: mode: 0755 want: 0755
> ========= /symlink =========
> initial tar image.
> @@ -11,35 +26,58 @@ initial tar image.
> Copy tar image to test.tar
> Untaring from file - successful
> +Untar from file into existing structure with one missing file - successful
> +Untar from file; overwrite empty directory with file - successful
> +Untar from file; file exists where parent dir should be created - expected fail
> +Untar from file; non-empty dir where file should be created - expected fail
> +Untar from file; overwrite file with explicit directory - successful
> ========= /dest/home/test_file =========
> initial tar image.
> +========= /dest/home/abc/def/test_script =========
> +(0)#! joel
> +ls -las /dev
> + /dest/home/abc/def/test_script: mode: 0755 want: 0755
> ========= /dest/symlink =========
> initial tar image.
> -Untaring chunks from memory - untar: dir: home
> -untar: file: home/test_file (73)
> +Untaring chunks from memory - untar: symlink: home/test_file -> symlink
> successful
> ========= /dest2/home/test_file =========
> initial tar image.
> +========= /dest2/home/abc/def/test_script =========
> +(0)#! joel
> +ls -las /dev
> + /dest2/home/abc/def/test_script: mode: 0755 want: 0755
> ========= /dest2/symlink =========
> initial tar image.
> -Untaring chunks from tgz- untar: dir: home
> -successful
> +Untaring chunks from tgz - successful
> ========= /dest3/home/test_file =========
> initial tar image.
> +========= /dest3/home/abc/def/test_script =========
> +(0)#! joel
> +ls -las /dev
> + /dest3/home/abc/def/test_script: mode: 0755 want: 0755
> ========= /dest3/symlink =========
> initial tar image.
> -*** END OF TAR01 TEST ***
> +*** END OF TEST TAR 1 ***
> diff --git a/testsuites/libtests/tar01/tar01.tar b/testsuites/libtests/tar01/tar01.tar
> index 6c6952ef183d51a9635c6ebbc8ed0443e8da1725..9874f426d15eb817f270af7dab48fce1f36be848 100644
> GIT binary patch
> literal 10240
> zcmeH}-%i6I6vlhKr#QxI9dtmSz{DGGboUFc)S*yJ=`?$L>C6^qR=rsp<Gzz7G(h<C
> z`}hvTjd!+w$%YJ;q9}@tv3w?S_NDAvwvlncWzL0CN at Ofg9c4!ODtI$(O>7sHb!M0)
> zu4Aj4w4~*#v9YzfUihOEmBDLUucK+=(e~X&cIDAdf3I>3#2pePlCC}abIuR-=Srnx
> zLTn6NXRiNzWh13eQ|B`Z6}g~GTR)Mm>3)85_duQZ;wHAnQ`H2Y8YZ^3$tsSLb;x at C
> zWUeP;XoWdWPGIYQ{kWW#rus~^aoO0{_LLKK{x78L^*_tyq5pFx(scp<pHhULu`Vy@
> zIT$x_k*=JMl+M8$yxarpA69SuU)p9m;NE`qKVygf=Tb6}ksNSM`=QVL{@?3A+zUJ9
> z{h!}|jEisjtC`@)|NApK;LojbF3@{uT#2+lAZH8>0w4eaAOHd&00JNY0w4eaAOHd&
> V00JNY0w4eaAOHd&00LtX_yCHOyx{-<
> literal 10240
> zcmeI!-)h1z6b5jw`xIyFdh?`zpJ11}*}Ru%Q=2VqM^7F2_Dfp^QXGoV;n)`hsW~ah
> z&wOdirZUUUNVhJmGmBXo`<BKrF^5qc^3iwS!>p7d6{RW-lY}|){VG$LubX8ylbi0P
> z)9r#;%tlLRb-gYp72{>zRNB_G7t_kAf^jMR;)X`2YHskiRcVF%M^nEEs42)bI=A(X
> zbWJa-r{`DdH-;RfGZhtWQ~8d-*49%w@^oY?y)%!&4XzDSIxkT6`PZB6GB?F|4#>8(
> zAKm$pmsj+G$dcqJ_uuEhm=z9_N&Z8{afbX~PJDIc{T;nE#syC3!D%7C4?dCQt2zJN
> zKsi*-*6*{<d&qz0^Zdi}-}g`R&nYJq4u{jsFDL)}`9JF)kDEgP0uX=z1Rwwb2tWV=
> g5P$##AOHafKmY;|fB*y_009U<00Izzz^@5>0Tj at K8~^|S
> 2.31.1
> devel mailing list
> devel at rtems.org
