[PATCH] untar: Make behavior similar to GNU or BSD tar
Christian MAUDERER
christian.mauderer at embedded-brains.de
Mon Dec 6 15:11:44 UTC 2021
Hello Joel,
thanks for the review. I'll apply it on master in the next few days.
The behavior that our untar can't overwrite directories is in 5 too. The
behavior on 5 changed last with the patches from ticket #3823 in
2019-11. I would lean to creating a ticket for 5 and apply the patch
there too. What do you think?
Best regards
Christian
Am 03.12.21 um 18:34 schrieb Joel Sherrill:
> I don't see anything that would stop this from being committed.
> This does make me realize that I think all of the untar capabilities
> are undocumented.
> --joel
> On Fri, Dec 3, 2021 at 6:51 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
>> RTEMS untar implementation had problems with overwriting or integrating
>> archives into existing directory structures. This patch adapts the
>> behavior to mimic that of a GNU tar or BSD tar and extends the tar01
>> test to check for the behavior. That is:
>> * If a directory structure exists, the files from the archive will be
>> integrated. Existing files are overwritten.
>> * If a file exists and the archive contains a directory with the same
>> name, the file is removed and a directory is created. In the above
>> example: if l1/l2 is a file it will be overwritten with a new
>> directory.
>> * If a directory exists and the archive contains a file with the same
>> name, the directory will be replaced if it is empty. If it contains
>> files, the result is an error.
>> * An archive also can contain only a file without the parent
>> directories. If in that case one of the parent directories exists as a
>> file extracting the archive results in an error. In the example: if
>> l1/l2 is a file and the archive doesn't contain the directories but
>> only the file l1/l2/x.txt that would be an error.
>> * In case of an error, it is possible that the archive has been
>> partially extracted.
>> Closes #4552
>> cpukit/libmisc/untar/untar.c | 57 +++++---
>> testsuites/libtests/tar01/init.c | 199 +++++++++++++++++++++++++++-
>> testsuites/libtests/tar01/tar01.doc | 1 +
>> testsuites/libtests/tar01/tar01.scn | 54 ++++++--
>> testsuites/libtests/tar01/tar01.tar | Bin 10240 -> 10240 bytes
>> 5 files changed, 282 insertions(+), 29 deletions(-)
>> diff --git a/cpukit/libmisc/untar/untar.c b/cpukit/libmisc/untar/untar.c
>> index a2f09fb99f..8888ab2c57 100644
>> --- a/cpukit/libmisc/untar/untar.c
>> +++ b/cpukit/libmisc/untar/untar.c
>> @@ -126,30 +126,25 @@ Make_Path(const rtems_printer *printer, char *path)
>> *p = '\0';
>> if (p[1] == '\0') {
>> - /* Speculatively unlink the last component so that it can be re-created */
>> - unlink(path);
>> return 0;
>> if (mkdir(path, S_IRWXU | S_IRWXG | S_IRWXO) != 0) {
>> - if (errno == EEXIST || errno == EISDIR) {
>> + if (errno == EEXIST) {
>> + /* If it exists already: Check whether it is a directory */
>> struct stat sb;
>> - if (stat(path, &sb) != 0) {
>> + if (lstat(path, &sb) != 0) {
>> + Print_Error(printer, "lstat", path);
>> + return -1;
>> + } else if (!S_ISDIR(sb.st_mode)) {
>> + rtems_printf(printer,
>> + "untar: mkdir: %s: exists but is not a directory\n",
>> + path);
>> return -1;
>> - if (!S_ISDIR(sb.st_mode)) {
>> - if (unlink(path) != 0) {
>> - Print_Error(printer, "unlink", path);
>> - return -1;
>> - if (mkdir(path, S_IRWXU | S_IRWXG | S_IRWXO) != 0) {
>> - Print_Error(printer, "mkdir (unlink)", path);
>> - return -1;
>> + } else {
>> + Print_Error(printer, "mkdir", path);
>> + return -1;
>> @@ -206,6 +201,12 @@ Untar_ProcessHeader(
>> if (Make_Path(ctx->printer, ctx->file_path) != 0) {
>> retval = UNTAR_FAIL;
>> + } else {
>> + * Speculatively unlink. This should unlink everything but non-empty
>> + * directories or write protected stuff.
>> + unlink(ctx->file_path);
>> if (ctx->linkflag == SYMTYPE) {
>> @@ -225,8 +226,22 @@ Untar_ProcessHeader(
>> rtems_printf(ctx->printer, "untar: dir: %s\n", ctx->file_path);
>> r = mkdir(ctx->file_path, ctx->mode);
>> if (r != 0) {
>> - Print_Error(ctx->printer, "mkdir", ctx->file_path);
>> - retval = UNTAR_FAIL;
>> + struct stat sb;
>> + if (lstat(ctx->file_path, &sb) != 0) {
>> + Print_Error(ctx->printer, "lstat", ctx->file_path);
>> + retval = UNTAR_FAIL;
>> + rtems_printf(ctx->printer,
>> + ctx->file_path);
>> + } else {
>> + Print_Error(ctx->printer, "mkdir", ctx->file_path);
>> @@ -426,7 +441,9 @@ Untar_FromFile_Print(
>> if ((out_fd = creat(ctx.file_path, ctx.mode)) == -1) {
>> - (void) lseek(fd, SEEK_CUR, 512UL * ctx.nblocks);
>> + /* Couldn't create that file. Abort. */
>> + break;
>> } else {
>> for (i = 0; i < ctx.nblocks; i++) {
>> n = read(fd, bufr, 512);
>> diff --git a/testsuites/libtests/tar01/init.c b/testsuites/libtests/tar01/init.c
>> index 4cad67a6ae..2deff3a482 100644
>> --- a/testsuites/libtests/tar01/init.c
>> +++ b/testsuites/libtests/tar01/init.c
>> @@ -7,6 +7,33 @@
>> * http://www.rtems.org/license/LICENSE.
>> + * Note on the used tar file: Generate the file on a system that supports
>> + * symlinks with the following commands (tested on Linux - you might have to
>> + * adapt on other systems):
>> + * export WORK=some_work_directory
>> + * rm -r ${WORK}
>> + * mkdir -p ${WORK}/home/abc/def
>> + * mkdir -p ${WORK}/home/dir
>> + * cd ${WORK}
>> + * echo "#! joel" > home/abc/def/test_script
>> + * echo "ls -las /dev" >> home/abc/def/test_script
>> + * chmod 755 home/abc/def/test_script
>> + * echo "This is a test of loading an RTEMS filesystem from an" > home/test_file
>> + * echo "initial tar image." >> home/test_file
>> + * echo "Hello world" >> home/dir/file
>> + * ln -s home/test_file symlink
>> + * tar cf tar01.tar --format=ustar \
>> + * symlink \
>> + * home/test_file \
>> + * home/abc/def/test_script \
>> + * home/dir
>> + * Note that "home/dir" is in the archive as separate directory. "home/abc" is
>> + * only in the archive as a parent of the file "test_script".
>> #ifdef HAVE_CONFIG_H
>> #include "config.h"
>> #endif
>> @@ -95,6 +122,84 @@ void test_untar_from_memory(void)
>> +static void assert_file_content(
>> + const char *name,
>> + const char *expected_content,
>> + ssize_t expected_size
>> + char buf[16];
>> + int fd;
>> + int rd;
>> + fd = open(name, O_RDONLY);
>> + rtems_test_assert( fd >= 0 );
>> + do {
>> + rd = read(fd, buf, sizeof(buf));
>> + rtems_test_assert( rd >= 0 );
>> + if (rd > 0) {
>> + rtems_test_assert( expected_size - rd >= 0 );
>> + rtems_test_assert( memcmp(buf, expected_content, rd) == 0 );
>> + expected_content += rd;
>> + expected_size -= rd;
>> + } while(rd > 0);
>> + rtems_test_assert( expected_size == 0 );
>> + close(fd);
>> +static void assert_content_like_expected(void)
>> + const char *directories[] = {
>> + "home",
>> + "home/abc",
>> + "home/abc/def",
>> + "home/dir",
>> + const char *symlinks[] = {
>> + "symlink",
>> + const struct {
>> + const char *name;
>> + const char *content;
>> + } files[] = {
>> + .name = "home/abc/def/test_script",
>> + .content = "#! joel\nls -las /dev\n",
>> + .name = "home/test_file",
>> + .content = "This is a test of loading an RTEMS filesystem from an\n"
>> + "initial tar image.\n",
>> + .name = "home/dir/file",
>> + .content = "Hello world\n",
>> + size_t i;
>> + struct stat st;
>> + for(i = 0; i < RTEMS_ARRAY_SIZE(directories); ++i) {
>> + lstat(directories[i], &st);
>> + rtems_test_assert( S_ISDIR(st.st_mode) );
>> + for(i = 0; i < RTEMS_ARRAY_SIZE(symlinks); ++i) {
>> + lstat(symlinks[i], &st);
>> + rtems_test_assert( S_ISLNK(st.st_mode) );
>> + for(i = 0; i < RTEMS_ARRAY_SIZE(files); ++i) {
>> + lstat(files[i].name, &st);
>> + rtems_test_assert( S_ISREG(st.st_mode) );
>> + assert_file_content(
>> + files[i].name,
>> + files[i].content,
>> + strlen(files[i].content)
>> void test_untar_from_file(void)
>> int fd;
>> @@ -119,13 +224,105 @@ void test_untar_from_file(void)
>> rv = chdir( "/dest" );
>> rtems_test_assert( rv == 0 );
>> - /* Untar it */
>> + /* Case 1: Untar it into empty directory */
>> rv = Untar_FromFile( "/test.tar" );
>> printf("Untaring from file - ");
>> if (rv != UNTAR_SUCCESSFUL) {
>> printf ("error: untar failed: %i\n", rv);
>> exit(1);
>> + assert_content_like_expected();
>> + printf ("successful\n");
>> + /* Case 2: Most files exist */
>> + rv = unlink("/dest/home/test_file");
>> + rtems_test_assert( rv == 0 );
>> + rv = Untar_FromFile( "/test.tar" );
>> + printf("Untar from file into existing structure with one missing file - ");
>> + if (rv != UNTAR_SUCCESSFUL) {
>> + printf ("error: untar failed: %i\n", rv);
>> + exit(1);
>> + /* Case 3: An empty directory exists where a file should be */
>> + rv = mkdir("/dest/home/test_file", S_IRWXU | S_IRWXG | S_IROTH | S_IXOTH);
>> + printf("Untar from file; overwrite empty directory with file - ");
>> + exit(1);
>> + /* Case 4: A file exists where a parent directory should be created */
>> + rv = unlink("/dest/home/abc/def/test_script");
>> + rv = unlink("/dest/home/abc/def");
>> + rv = unlink("/dest/home/abc");
>> + fd = creat("/dest/home/abc", S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH);
>> + close(fd);
>> + printf("Untar from file; file exists where parent dir should be created - ");
>> + if (rv != UNTAR_FAIL) {
>> + printf ("error: untar didn't fail like expected: %i\n", rv);
>> + exit(1);
>> + printf ("expected fail\n");
>> + /* cleanup so that the next one works */
>> + /* Case 5: A non-empty directory exists where a file should be created */
>> + fd = creat("/dest/home/test_file/file",
>> + S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH);
>> + close(fd);
>> + printf("Untar from file; non-empty dir where file should be created - ");
>> + exit(1);
>> + rv = unlink("/dest/home/test_file/file");
>> + /* Case 6: A file exists where a directory is explicitly in the archive */
>> + rv = unlink("/dest/home/dir/file");
>> + rv = unlink("/dest/home/dir");
>> + fd = creat("/dest/home/dir", S_IRUSR | S_IWUSR | S_IRGRP | S_IROTH);
>> + close(fd);
>> + printf("Untar from file; overwrite file with explicit directory - ");
>> + exit(1);
>> diff --git a/testsuites/libtests/tar01/tar01.doc b/testsuites/libtests/tar01/tar01.doc
>> index 060f98a813..adffdca291 100644
>> --- a/testsuites/libtests/tar01/tar01.doc
>> +++ b/testsuites/libtests/tar01/tar01.doc
>> @@ -20,3 +20,4 @@ directives:
>> concepts:
>> + exercise these routines
>> ++ check whether existing files are overwritten or not overwritten like expected
>> diff --git a/testsuites/libtests/tar01/tar01.scn b/testsuites/libtests/tar01/tar01.scn
>> index 68fa951881..dd72f9517b 100644
>> --- a/testsuites/libtests/tar01/tar01.scn
>> +++ b/testsuites/libtests/tar01/tar01.scn
>> @@ -1,9 +1,24 @@
>> -*** TAR01 TEST ***
>> -Untaring from memory - successful
>> +*** BEGIN OF TEST TAR 1 ***
>> +*** TEST VERSION: 6.0.0.e1efb4eb8a9d6dd5f6f37dafc9feb0a9e6a888f1
>> +*** TEST STATE: EXPECTED_PASS
>> +*** TEST BUILD: RTEMS_POSIX_API
>> +*** TEST TOOLS: 10.3.1 20210409 (RTEMS 6, RSB ad54d1dd3cf8249d9d39deb1dd28b2f294df062d-modified, Newlib eb03ac1)
>> +Untaring from memory - untar: memory at 0x11ece8 (10240)
>> +untar: symlink: home/test_file -> symlink
>> +untar: file: home/test_file (s:73,m:0644)
>> +untar: file: home/abc/def/test_script (s:21,m:0755)
>> +untar: dir: home/dir
>> +untar: file: home/dir/file (s:12,m:0644)
>> +successful
>> ========= /home/test_file =========
>> (0)This is a test of loading an RTEMS filesystem from an
>> initial tar image.
>> +========= /home/abc/def/test_script =========
>> +(0)#! joel
>> +ls -las /dev
>> + /home/abc/def/test_script: mode: 0755 want: 0755
>> ========= /symlink =========
>> initial tar image.
>> @@ -11,35 +26,58 @@ initial tar image.
>> Copy tar image to test.tar
>> Untaring from file - successful
>> +Untar from file into existing structure with one missing file - successful
>> +Untar from file; overwrite empty directory with file - successful
>> +Untar from file; file exists where parent dir should be created - expected fail
>> +Untar from file; non-empty dir where file should be created - expected fail
>> +Untar from file; overwrite file with explicit directory - successful
>> ========= /dest/home/test_file =========
>> initial tar image.
>> +========= /dest/home/abc/def/test_script =========
>> +(0)#! joel
>> +ls -las /dev
>> + /dest/home/abc/def/test_script: mode: 0755 want: 0755
>> ========= /dest/symlink =========
>> initial tar image.
>> -Untaring chunks from memory - untar: dir: home
>> -untar: file: home/test_file (73)
>> +Untaring chunks from memory - untar: symlink: home/test_file -> symlink
>> successful
>> ========= /dest2/home/test_file =========
>> initial tar image.
>> +========= /dest2/home/abc/def/test_script =========
>> +(0)#! joel
>> +ls -las /dev
>> + /dest2/home/abc/def/test_script: mode: 0755 want: 0755
>> ========= /dest2/symlink =========
>> initial tar image.
>> -Untaring chunks from tgz- untar: dir: home
>> -successful
>> +Untaring chunks from tgz - successful
>> ========= /dest3/home/test_file =========
>> initial tar image.
>> +========= /dest3/home/abc/def/test_script =========
>> +(0)#! joel
>> +ls -las /dev
>> + /dest3/home/abc/def/test_script: mode: 0755 want: 0755
>> ========= /dest3/symlink =========
>> initial tar image.
>> -*** END OF TAR01 TEST ***
>> +*** END OF TEST TAR 1 ***
>> diff --git a/testsuites/libtests/tar01/tar01.tar b/testsuites/libtests/tar01/tar01.tar
>> index 6c6952ef183d51a9635c6ebbc8ed0443e8da1725..9874f426d15eb817f270af7dab48fce1f36be848 100644
>> GIT binary patch
>> literal 10240
>> zcmeH}-%i6I6vlhKr#QxI9dtmSz{DGGboUFc)S*yJ=`?$L>C6^qR=rsp<Gzz7G(h<C
>> z`}hvTjd!+w$%YJ;q9}@tv3w?S_NDAvwvlncWzL0CN at Ofg9c4!ODtI$(O>7sHb!M0)
>> zu4Aj4w4~*#v9YzfUihOEmBDLUucK+=(e~X&cIDAdf3I>3#2pePlCC}abIuR-=Srnx
>> zLTn6NXRiNzWh13eQ|B`Z6}g~GTR)Mm>3)85_duQZ;wHAnQ`H2Y8YZ^3$tsSLb;x at C
>> zWUeP;XoWdWPGIYQ{kWW#rus~^aoO0{_LLKK{x78L^*_tyq5pFx(scp<pHhULu`Vy@
>> zIT$x_k*=JMl+M8$yxarpA69SuU)p9m;NE`qKVygf=Tb6}ksNSM`=QVL{@?3A+zUJ9
>> z{h!}|jEisjtC`@)|NApK;LojbF3@{uT#2+lAZH8>0w4eaAOHd&00JNY0w4eaAOHd&
>> V00JNY0w4eaAOHd&00LtX_yCHOyx{-<
>> literal 10240
>> zcmeI!-)h1z6b5jw`xIyFdh?`zpJ11}*}Ru%Q=2VqM^7F2_Dfp^QXGoV;n)`hsW~ah
>> z&wOdirZUUUNVhJmGmBXo`<BKrF^5qc^3iwS!>p7d6{RW-lY}|){VG$LubX8ylbi0P
>> z)9r#;%tlLRb-gYp72{>zRNB_G7t_kAf^jMR;)X`2YHskiRcVF%M^nEEs42)bI=A(X
>> zbWJa-r{`DdH-;RfGZhtWQ~8d-*49%w@^oY?y)%!&4XzDSIxkT6`PZB6GB?F|4#>8(
>> zAKm$pmsj+G$dcqJ_uuEhm=z9_N&Z8{afbX~PJDIc{T;nE#syC3!D%7C4?dCQt2zJN
>> zKsi*-*6*{<d&qz0^Zdi}-}g`R&nYJq4u{jsFDL)}`9JF)kDEgP0uX=z1Rwwb2tWV=
>> g5P$##AOHafKmY;|fB*y_009U<00Izzz^@5>0Tj at K8~^|S
>> 2.31.1
>> devel mailing list
>> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
