[PATCH] score: Add _IO_Relax()
Fri Dec 10 08:11:07 UTC 2021
This function may be used to burn a couple of processor cycles with
minimum impact on the system bus.  It may be used in busy wait loops.
Since it is a global function, it is possible to wrap it in device
driver test code.
 cpukit/include/rtems/score/io.h   |  8 +++++
 cpukit/score/src/iorelax.c        | 53 +++++++++++++++++++++++++++++++
 spec/build/cpukit/librtemscpu.yml |  1 +
 3 files changed, 62 insertions(+)
 create mode 100644 cpukit/score/src/iorelax.c
diff --git a/cpukit/include/rtems/score/io.h b/cpukit/include/rtems/score/io.h
index f7b576fddd..5cc946bba8 100644
--- a/cpukit/include/rtems/score/io.h
+++ b/cpukit/include/rtems/score/io.h
@@ -120,6 +120,14 @@ int _IO_Base64url(
   int          wordlen
+ * @brief Issues a couple of no-operation instructions.
+ * This function may be used to burn a couple of processor cycles with minimum
+ * impact on the system bus.  It may be used in busy wait loops.
+void _IO_Relax( void );
 #ifdef __cplusplus
diff --git a/cpukit/score/src/iorelax.c b/cpukit/score/src/iorelax.c
new file mode 100644
index 0000000000..f37d848605
--- /dev/null
+++ b/cpukit/score/src/iorelax.c
@@ -0,0 +1,53 @@
+ * @file
+ * @ingroup RTEMSScoreIO
+ * @brief This source file contains the implementation of _IO_Relax().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/io.h>
+#include <rtems/score/cpuimpl.h>
+  _CPU_Instruction_no_operation();
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 423974502c..f8594a7784 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1421,6 +1421,7 @@ source:
 - cpukit/score/src/interr.c
 - cpukit/score/src/iobase64.c
 - cpukit/score/src/ioprintf.c
+- cpukit/score/src/iorelax.c
 - cpukit/score/src/iovprintf.c
 - cpukit/score/src/isr.c
 - cpukit/score/src/isrisinprogress.c
2.31.1
