[PATCH 1/4] bsp/leon3: Use interrupt entry for Clock Driver
Fri Dec 10 13:38:31 UTC 2021
Using rtems_interrupt_entry_install() instead of
rtems_interrupt_handler_install() avoids a dependency on the dynamic memory
allocation.
 bsps/sparc/leon3/clock/ckinit.c | 14 ++++++++++----
 1 file changed, 10 insertions(+), 4 deletions(-)
diff --git a/bsps/sparc/leon3/clock/ckinit.c b/bsps/sparc/leon3/clock/ckinit.c
index 4d30e0fd64..69afb25f3c 100644
--- a/bsps/sparc/leon3/clock/ckinit.c
+++ b/bsps/sparc/leon3/clock/ckinit.c
@@ -133,16 +133,22 @@ static void leon3_tc_do_tick(void)
 #define Clock_driver_support_install_isr(isr) \
   bsp_clock_handler_install(isr)
+static rtems_interrupt_entry leon3_clock_interrupt_entry;
 static void bsp_clock_handler_install(rtems_interrupt_handler isr)
   rtems_status_code sc;
-  sc = rtems_interrupt_handler_install(
+  rtems_interrupt_entry_initialize(
+    &leon3_clock_interrupt_entry,
+    isr,
+    NULL,
+    "Clock"
+  sc = rtems_interrupt_entry_install(
     clkirq,
-    "Clock",
     RTEMS_INTERRUPT_UNIQUE,
-    isr,
-    NULL
   if (sc != RTEMS_SUCCESSFUL) {
     rtems_fatal(RTEMS_FATAL_SOURCE_BSP, LEON3_FATAL_CLOCK_INITIALIZATION);
2.26.2
