[PATCH 3/4] bsp/leon3: Use interrupt entry for tm27 support
Sebastian Huber
Fri Dec 10 13:38:33 UTC 2021
Using rtems_interrupt_entry_install() instead of
rtems_interrupt_handler_install() avoids a dependency on the dynamic memory
allocation.
Use Interrupt Manager directives instead of a BSP-specific API. Use inline
functions. In SMP configurations, set an affinity to all online processors and
raise the interrupt on the current processor.
bsps/sparc/leon3/include/tm27.h | 75 ++++++++++++++++++++++++---------
1 file changed, 55 insertions(+), 20 deletions(-)
diff --git a/bsps/sparc/leon3/include/tm27.h b/bsps/sparc/leon3/include/tm27.h
index dda21f558f..7635d9b070 100644
--- a/bsps/sparc/leon3/include/tm27.h
+++ b/bsps/sparc/leon3/include/tm27.h
@@ -21,7 +21,11 @@
#define __tm27_h
#include <bsp.h>
-#include <leon.h>
+#include <bsp/irq.h>
+#if defined(RTEMS_SMP)
+#include <rtems/score/smpimpl.h>
+#endif
* Define the interrupt mechanism for Time Test 27
@@ -59,40 +63,71 @@
#else /* use a regular asynchronous trap */
-#define TEST_INTERRUPT_SOURCE LEON_INTERRUPT_EXTERNAL_1
-#define TEST_INTERRUPT_SOURCE2 LEON_INTERRUPT_EXTERNAL_1+1
+#define TEST_INTERRUPT_SOURCE 5
+#define TEST_INTERRUPT_SOURCE2 6
#define MUST_WAIT_FOR_INTERRUPT 1
static inline void Install_tm27_vector(
void ( *handler )( rtems_vector_number )
- (void) rtems_interrupt_handler_install(
+ static rtems_interrupt_entry entry_low;
+ static rtems_interrupt_entry entry_high;
+ bsp_interrupt_set_affinity(
+ TEST_INTERRUPT_SOURCE,
+ _SMP_Get_online_processors()
+ TEST_INTERRUPT_SOURCE2,
+#endif
+ rtems_interrupt_entry_initialize(
+ &entry_low,
+ (rtems_interrupt_handler) handler,
+ NULL,
+ "tm27 low"
+ (void) rtems_interrupt_entry_install(
- "tm27 low",
RTEMS_INTERRUPT_SHARED,
+ &entry_low
+ &entry_high,
- NULL
+ NULL,
+ "tm27 high"
- "tm27 high",
- (rtems_interrupt_handler) handler,
- NULL
+ &entry_high
-#define Cause_tm27_intr() \
- do { \
- LEON_Force_interrupt( TEST_INTERRUPT_SOURCE+(Interrupt_nest>>1)); \
- nop(); \
- nop(); \
- nop(); \
- } while (0)
-#define Clear_tm27_intr() \
- LEON_Clear_interrupt( TEST_INTERRUPT_SOURCE )
+static inline void Cause_tm27_intr( void )
+ rtems_vector_number vector;
+ vector = TEST_INTERRUPT_SOURCE + ( Interrupt_nest >> 1 );
+ (void) rtems_interrupt_raise_on( vector, rtems_scheduler_get_processor() );
+#else
+ (void) rtems_interrupt_raise( vector );
+#endif
+ nop();
+ nop();
+ nop();
+static inline void Clear_tm27_intr( void )
+ (void) rtems_interrupt_clear( TEST_INTERRUPT_SOURCE );
#define Lower_tm27_intr() /* empty */
2.26.2
