[PATCH v2 1/3] aarch64: add internal API for secure monitor call (smc)
Gedare Bloom
gedare at rtems.org
Sat Dec 11 16:16:02 UTC 2021
cpukit/score/cpu/aarch64/aarch64-smc.c | 72 ++++++++++++++++
.../aarch64/include/rtems/score/aarch64-smc.h | 83 +++++++++++++++++++
spec/build/cpukit/cpuaarch64.yml | 2 +
3 files changed, 157 insertions(+)
create mode 100644 cpukit/score/cpu/aarch64/aarch64-smc.c
create mode 100644 cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
diff --git a/cpukit/score/cpu/aarch64/aarch64-smc.c b/cpukit/score/cpu/aarch64/aarch64-smc.c
new file mode 100644
index 0000000000..c531d074d8
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/aarch64-smc.c
@@ -0,0 +1,72 @@
+ * @file
+ * @brief This source file contains the implementation of
+ * _AArch64_SMC_Invoke().
+ * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/aarch64-smc.h>
+int _AArch64_SMC_Invoke(
+ uint32_t function_id,
+ uintptr_t arg0,
+ uintptr_t arg1,
+ uintptr_t arg2,
+ uintptr_t arg3,
+ uintptr_t arg4,
+ uintptr_t arg5,
+ uintptr_t arg6,
+ AArch64_SMC_Return *result
+ int rv;
+ /* This only works for SMC that return 4 or fewer results. It may be extended
+ * up to the full 18 return results specified for SMC64, but then we would
+ * need to allocate a callee-saved register for *result */
+ __asm__ volatile(
+ "smc #0\n"
+ "mov %0, x0\n"
+ "ldr x15, [sp]\n"
+ "cbz x15, 0f\n"
+ "stp x0, x1, [x15]\n"
+ "stp x2, x3, [x15, #16]\n"
+ "0:\n"
+ : "=r" ( rv )
+ : "x0", "x1", "x2", "x3", "x15"
+ return rv;
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
index 0000000000..e80cc1e99b
--- /dev/null
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
@@ -0,0 +1,83 @@
+ * @file
+ * @ingroup RTEMSScoreCPUAArch64
+ * @brief This header file provides API to wrap secure monitor calls (smc).
+ * are met:
+#ifndef _RTEMS_SCORE_AARCH64_SMC_H
+#define _RTEMS_SCORE_AARCH64_SMC_H
+#include <rtems/score/basedefs.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMSScoreCPUAArch64SMC Secure Monitor Call Support
+ * @brief This group provides functions to invoke secure monitor mode.
+ * @brief The return result from smc invocation.
+typedef struct {
+ uintptr_t x0;
+ uintptr_t x1;
+ uintptr_t x2;
+ uintptr_t x3;
+} AArch64_SMC_Return;
+ uintptr_t arg0,
+ uintptr_t arg1,
+ uintptr_t arg2,
+ uintptr_t arg3,
+ uintptr_t arg4,
+ uintptr_t arg5,
+ uintptr_t arg6,
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_SCORE_AARCH64_SMC_H */
diff --git a/spec/build/cpukit/cpuaarch64.yml b/spec/build/cpukit/cpuaarch64.yml
index 70d80f0b6c..1f3f07f0a2 100644
--- a/spec/build/cpukit/cpuaarch64.yml
+++ b/spec/build/cpukit/cpuaarch64.yml
@@ -19,6 +19,7 @@ install:
- destination: ${BSP_INCLUDEDIR}/rtems/score
source:
- cpukit/score/cpu/aarch64/include/rtems/score/aarch64-system-registers.h
+ - cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
- cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
- cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
- cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
@@ -32,6 +33,7 @@ source:
- cpukit/score/cpu/aarch64/aarch64-exception-default.c
- cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
- cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
+- cpukit/score/cpu/aarch64/aarch64-smc.c
- cpukit/score/cpu/aarch64/aarch64-thread-idle.c
- cpukit/score/cpu/aarch64/cpu.c
- cpukit/score/cpu/aarch64/cpu_asm.S
2.25.1
