[PATCH v2 1/3] aarch64: add internal API for secure monitor call (smc)
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Dec 13 14:28:22 UTC 2021
Everything else looks good. Just one nit below.
On 12/11/2021 10:16, Gedare Bloom wrote:
> cpukit/score/cpu/aarch64/aarch64-smc.c | 72 ++++++++++++++++
> .../aarch64/include/rtems/score/aarch64-smc.h | 83 +++++++++++++++++++
> spec/build/cpukit/cpuaarch64.yml | 2 +
> 3 files changed, 157 insertions(+)
> create mode 100644 cpukit/score/cpu/aarch64/aarch64-smc.c
> create mode 100644 cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> diff --git a/cpukit/score/cpu/aarch64/aarch64-smc.c b/cpukit/score/cpu/aarch64/aarch64-smc.c
> new file mode 100644
> index 0000000000..c531d074d8
> --- /dev/null
> +++ b/cpukit/score/cpu/aarch64/aarch64-smc.c
> @@ -0,0 +1,72 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @brief This source file contains the implementation of
> + * _AArch64_SMC_Invoke().
> + * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/score/aarch64-smc.h>
> +int _AArch64_SMC_Invoke(
> + uint32_t function_id,
> + uintptr_t arg0,
> + uintptr_t arg1,
> + uintptr_t arg2,
> + uintptr_t arg3,
> + uintptr_t arg4,
> + uintptr_t arg5,
> + uintptr_t arg6,
The SMC arguments here should be uint64_t for all AArch64 calls
regardless of ABI.
> + AArch64_SMC_Return *result
> + int rv;
> + /* This only works for SMC that return 4 or fewer results. It may be extended
> + * up to the full 18 return results specified for SMC64, but then we would
> + * need to allocate a callee-saved register for *result */
> + __asm__ volatile(
> + "smc #0\n"
> + "mov %0, x0\n"
> + "ldr x15, [sp]\n"
> + "cbz x15, 0f\n"
> + "stp x0, x1, [x15]\n"
> + "stp x2, x3, [x15, #16]\n"
> + "0:\n"
> + : "=r" ( rv )
> + : "x0", "x1", "x2", "x3", "x15"
> + return rv;
> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> index 0000000000..e80cc1e99b
> --- /dev/null
> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> @@ -0,0 +1,83 @@
> + * @file
> + * @ingroup RTEMSScoreCPUAArch64
> + * @brief This header file provides API to wrap secure monitor calls (smc).
> + * are met:
> +#ifndef _RTEMS_SCORE_AARCH64_SMC_H
> +#define _RTEMS_SCORE_AARCH64_SMC_H
> +#include <rtems/score/basedefs.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * @defgroup RTEMSScoreCPUAArch64SMC Secure Monitor Call Support
> + * @brief This group provides functions to invoke secure monitor mode.
> + * @brief The return result from smc invocation.
> +typedef struct {
> + uintptr_t x0;
> + uintptr_t x1;
> + uintptr_t x2;
> + uintptr_t x3;
> +} AArch64_SMC_Return;
> + uintptr_t arg0,
> + uintptr_t arg1,
> + uintptr_t arg2,
> + uintptr_t arg3,
> + uintptr_t arg4,
> + uintptr_t arg5,
> + uintptr_t arg6,
> +#ifdef __cplusplus
> +#endif
> +#endif /* _RTEMS_SCORE_AARCH64_SMC_H */
> diff --git a/spec/build/cpukit/cpuaarch64.yml b/spec/build/cpukit/cpuaarch64.yml
> index 70d80f0b6c..1f3f07f0a2 100644
> --- a/spec/build/cpukit/cpuaarch64.yml
> +++ b/spec/build/cpukit/cpuaarch64.yml
> @@ -19,6 +19,7 @@ install:
> - destination: ${BSP_INCLUDEDIR}/rtems/score
> source:
> - cpukit/score/cpu/aarch64/include/rtems/score/aarch64-system-registers.h
> + - cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> - cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> - cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
> - cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> @@ -32,6 +33,7 @@ source:
> - cpukit/score/cpu/aarch64/aarch64-exception-default.c
> - cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> - cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> +- cpukit/score/cpu/aarch64/aarch64-smc.c
> - cpukit/score/cpu/aarch64/aarch64-thread-idle.c
> - cpukit/score/cpu/aarch64/cpu.c
> - cpukit/score/cpu/aarch64/cpu_asm.S
