[PATCH] bsps/aarch64: Remove erroneous cache feature
Gedare Bloom
gedare at rtems.org
Sat Dec 11 18:18:00 UTC 2021
On Fri, Dec 10, 2021 at 10:19 AM Sebastian Huber
> On 10/12/2021 16:49, Kinsey Moore wrote:
> > The AArch64 cache implementation does not define
> > rtems_cache_disable_data(), but declares that it does via
> > CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA. The existing implementation of
> > _CPU_cache_disable_data() is sufficient to enable this functionality
> > without the erroneous cache feature flag.
> > Closes #4569
> Thanks, please check it in.
> At least for ARMv7 we have an assembler implementation for this function:
> bsps/arm/shared/cache/cache-v7ar-disable-data.S
Basically the same code should work for aarch64, replacing the access
with SCTLR_EL3
mrs x0, SCTLR_EL1
bic x0, x0, #0x4
msr SCTLR_EL1, x0
isb
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
