[PATCH] bsps/aarch64: Remove erroneous cache feature
Gedare Bloom
gedare at rtems.org
Sat Dec 11 18:18:30 UTC 2021
On Sat, Dec 11, 2021 at 11:18 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Dec 10, 2021 at 10:19 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > On 10/12/2021 16:49, Kinsey Moore wrote:
> > > The AArch64 cache implementation does not define
> > > rtems_cache_disable_data(), but declares that it does via
> > > CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA. The existing implementation of
> > > _CPU_cache_disable_data() is sufficient to enable this functionality
> > > without the erroneous cache feature flag.
> > > Closes #4569
> > Thanks, please check it in.
> > At least for ARMv7 we have an assembler implementation for this function:
> > bsps/arm/shared/cache/cache-v7ar-disable-data.S
> Basically the same code should work for aarch64, replacing the access
> with SCTLR_EL3
I meant EL1 :) the following code snippet should work anyway.
> mrs x0, SCTLR_EL1
> bic x0, x0, #0x4
> msr SCTLR_EL1, x0
> isb
> > embedded brains GmbH
> > Herr Sebastian HUBER
> > Dornierstr. 4
> > 82178 Puchheim
> > Germany
> > email: sebastian.huber at embedded-brains.de
> > phone: +49-89-18 94 741 - 16
> > fax: +49-89-18 94 741 - 08
> > Registergericht: Amtsgericht München
> > Registernummer: HRB 157899
> > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> > Unsere Datenschutzerklärung finden Sie hier:
> > https://embedded-brains.de/datenschutzerklaerung/
> > devel mailing list
> > devel at rtems.org
