[PATCH v2 1/3] aarch64: add internal API for secure monitor call (smc)
Kinsey Moore kinsey.moore at oarcorp.com
Tue Dec 14 02:18:06 UTC 2021
On 12/13/2021 19:56, Gedare Bloom wrote:
> On Mon, Dec 13, 2021 at 9:55 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
>> Everything else looks good. Just one nit below.
>> On 12/11/2021 10:16, Gedare Bloom wrote:
>>>    cpukit/score/cpu/aarch64/aarch64-smc.c        | 72 ++++++++++++++++
>>>    .../aarch64/include/rtems/score/aarch64-smc.h | 83 +++++++++++++++++++
>>>    spec/build/cpukit/cpuaarch64.yml              |  2 +
>>>    3 files changed, 157 insertions(+)
>>>    create mode 100644 cpukit/score/cpu/aarch64/aarch64-smc.c
>>>    create mode 100644 cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
>>> diff --git a/cpukit/score/cpu/aarch64/aarch64-smc.c b/cpukit/score/cpu/aarch64/aarch64-smc.c
>>> new file mode 100644
>>> index 0000000000..c531d074d8
>>> --- /dev/null
>>> +++ b/cpukit/score/cpu/aarch64/aarch64-smc.c
>>> @@ -0,0 +1,72 @@
>>> +/* SPDX-License-Identifier: BSD-2-Clause */
>>> + *  @file
>>> + *  @brief This source file contains the implementation of
>>> + *    _AArch64_SMC_Invoke().
>>> + * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
>>> + * Redistribution and use in source and binary forms, with or without
>>> + * modification, are permitted provided that the following conditions
>>> + * are met:
>>> + * 1. Redistributions of source code must retain the above copyright
>>> + *    notice, this list of conditions and the following disclaimer.
>>> + * 2. Redistributions in binary form must reproduce the above copyright
>>> + *    notice, this list of conditions and the following disclaimer in the
>>> + *    documentation and/or other materials provided with the distribution.
>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>>> + * POSSIBILITY OF SUCH DAMAGE.
>>> +#ifdef HAVE_CONFIG_H
>>> +#include "config.h"
>>> +#endif
>>> +#include <rtems/score/aarch64-smc.h>
>>> +int _AArch64_SMC_Invoke(
>>> +  uint32_t function_id,
>>> +  uintptr_t arg0,
>>> +  uintptr_t arg1,
>>> +  uintptr_t arg2,
>>> +  uintptr_t arg3,
>>> +  uintptr_t arg4,
>>> +  uintptr_t arg5,
>>> +  uintptr_t arg6,
>> The SMC arguments here should be uint64_t for all AArch64 calls
>> regardless of ABI.
> This shouldn't matter, since AArch64 calls will have LP64? I guess I
> can change it. My thinking was that if we want to later add
> _AArch32_SMC_Invoke() it can have almost the exact same prototype as
> this function (except the return type but even that is a pointer),
> which might simplify some programming.
The problem is that AArch64 has the LP64 and ILP32 ABIs which both use
SMC64 since ILP32 is really just normal AArch64 instructions, memory
space, and 64-bit registers under the hood. AArch32/ARMv7 has the same
data model as AArch64/ILP32, but AArch32/ARMv7 uses SMC32 calls since
it's 32-bit registers. This all assumes that I've read/remember the
specs correctly.
>>> +  AArch64_SMC_Return *result
>>> +  int rv;
>>> +  /* This only works for SMC that return 4 or fewer results. It may be extended
>>> +   * up to the full 18 return results specified for SMC64, but then we would
>>> +   * need to allocate a callee-saved register for *result */
>>> +  __asm__ volatile(
>>> +    "smc  #0\n"
>>> +    "mov  %0, x0\n"
>>> +    "ldr  x15, [sp]\n"
>>> +    "cbz  x15, 0f\n"
>>> +    "stp  x0, x1, [x15]\n"
>>> +    "stp  x2, x3, [x15, #16]\n"
>>> +    "0:\n"
>>> +    : "=r" ( rv )
>>> +    : "x0", "x1", "x2", "x3", "x15"
>>> +  return rv;
>>> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
>>> index 0000000000..e80cc1e99b
>>> --- /dev/null
>>> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
>>> @@ -0,0 +1,83 @@
>>> + * @file
>>> + * @ingroup RTEMSScoreCPUAArch64
>>> + * @brief This header file provides API to wrap secure monitor calls (smc).
>>> + * are met:
>>> +#ifndef _RTEMS_SCORE_AARCH64_SMC_H
>>> +#define _RTEMS_SCORE_AARCH64_SMC_H
>>> +#include <rtems/score/basedefs.h>
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +#endif
>>> + * @defgroup RTEMSScoreCPUAArch64SMC Secure Monitor Call Support
>>> + * @brief This group provides functions to invoke secure monitor mode.
>>> + * @brief The return result from smc invocation.
>>> +typedef struct {
>>> +  uintptr_t x0;
>>> +  uintptr_t x1;
>>> +  uintptr_t x2;
>>> +  uintptr_t x3;
>>> +} AArch64_SMC_Return;
>>> +  uintptr_t arg0,
>>> +  uintptr_t arg1,
>>> +  uintptr_t arg2,
>>> +  uintptr_t arg3,
>>> +  uintptr_t arg4,
>>> +  uintptr_t arg5,
>>> +  uintptr_t arg6,
>>> +#ifdef __cplusplus
>>> +#endif
>>> +#endif /* _RTEMS_SCORE_AARCH64_SMC_H */
>>> diff --git a/spec/build/cpukit/cpuaarch64.yml b/spec/build/cpukit/cpuaarch64.yml
>>> index 70d80f0b6c..1f3f07f0a2 100644
>>> --- a/spec/build/cpukit/cpuaarch64.yml
>>> +++ b/spec/build/cpukit/cpuaarch64.yml
>>> @@ -19,6 +19,7 @@ install:
>>>    - destination: ${BSP_INCLUDEDIR}/rtems/score
>>>      source:
>>>      - cpukit/score/cpu/aarch64/include/rtems/score/aarch64-system-registers.h
>>> +  - cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
>>>      - cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
>>>      - cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
>>>      - cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
>>> @@ -32,6 +33,7 @@ source:
>>>    - cpukit/score/cpu/aarch64/aarch64-exception-default.c
>>>    - cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
>>>    - cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
>>> +- cpukit/score/cpu/aarch64/aarch64-smc.c
>>>    - cpukit/score/cpu/aarch64/aarch64-thread-idle.c
>>>    - cpukit/score/cpu/aarch64/cpu.c
>>>    - cpukit/score/cpu/aarch64/cpu_asm.S
>> devel mailing list
>> devel at rtems.org
