[PATCH v2 1/3] aarch64: add internal API for secure monitor call (smc)
Gedare Bloom
gedare at rtems.org
Tue Dec 14 02:45:46 UTC 2021
On Mon, Dec 13, 2021 at 7:18 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> On 12/13/2021 19:56, Gedare Bloom wrote:
> > On Mon, Dec 13, 2021 at 9:55 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> >> Everything else looks good. Just one nit below.
> >> On 12/11/2021 10:16, Gedare Bloom wrote:
> >>> cpukit/score/cpu/aarch64/aarch64-smc.c | 72 ++++++++++++++++
> >>> .../aarch64/include/rtems/score/aarch64-smc.h | 83 +++++++++++++++++++
> >>> spec/build/cpukit/cpuaarch64.yml | 2 +
> >>> 3 files changed, 157 insertions(+)
> >>> create mode 100644 cpukit/score/cpu/aarch64/aarch64-smc.c
> >>> create mode 100644 cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> >>> diff --git a/cpukit/score/cpu/aarch64/aarch64-smc.c b/cpukit/score/cpu/aarch64/aarch64-smc.c
> >>> new file mode 100644
> >>> index 0000000000..c531d074d8
> >>> --- /dev/null
> >>> +++ b/cpukit/score/cpu/aarch64/aarch64-smc.c
> >>> @@ -0,0 +1,72 @@
> >>> +/* SPDX-License-Identifier: BSD-2-Clause */
> >>> + * @file
> >>> + * @brief This source file contains the implementation of
> >>> + * _AArch64_SMC_Invoke().
> >>> + * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
> >>> + * Redistribution and use in source and binary forms, with or without
> >>> + * modification, are permitted provided that the following conditions
> >>> + * are met:
> >>> + * 1. Redistributions of source code must retain the above copyright
> >>> + * notice, this list of conditions and the following disclaimer.
> >>> + * 2. Redistributions in binary form must reproduce the above copyright
> >>> + * notice, this list of conditions and the following disclaimer in the
> >>> + * documentation and/or other materials provided with the distribution.
> >>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> >>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> >>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> >>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> >>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> >>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> >>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> >>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> >>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> >>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> >>> + * POSSIBILITY OF SUCH DAMAGE.
> >>> +#ifdef HAVE_CONFIG_H
> >>> +#include "config.h"
> >>> +#endif
> >>> +#include <rtems/score/aarch64-smc.h>
> >>> +int _AArch64_SMC_Invoke(
> >>> + uint32_t function_id,
> >>> + uintptr_t arg0,
> >>> + uintptr_t arg1,
> >>> + uintptr_t arg2,
> >>> + uintptr_t arg3,
> >>> + uintptr_t arg4,
> >>> + uintptr_t arg5,
> >>> + uintptr_t arg6,
> >> The SMC arguments here should be uint64_t for all AArch64 calls
> >> regardless of ABI.
> > This shouldn't matter, since AArch64 calls will have LP64? I guess I
> > can change it. My thinking was that if we want to later add
> > _AArch32_SMC_Invoke() it can have almost the exact same prototype as
> > this function (except the return type but even that is a pointer),
> > which might simplify some programming.
> The problem is that AArch64 has the LP64 and ILP32 ABIs which both use
> SMC64 since ILP32 is really just normal AArch64 instructions, memory
> space, and 64-bit registers under the hood. AArch32/ARMv7 has the same
> data model as AArch64/ILP32, but AArch32/ARMv7 uses SMC32 calls since
> it's 32-bit registers. This all assumes that I've read/remember the
> specs correctly.
I see. I will change it to uint64_t, it won't hurt anything for me.
I'll probably check these in tomorrow.
> >>> + AArch64_SMC_Return *result
> >>> + int rv;
> >>> + /* This only works for SMC that return 4 or fewer results. It may be extended
> >>> + * up to the full 18 return results specified for SMC64, but then we would
> >>> + * need to allocate a callee-saved register for *result */
> >>> + __asm__ volatile(
> >>> + "smc #0\n"
> >>> + "mov %0, x0\n"
> >>> + "ldr x15, [sp]\n"
> >>> + "cbz x15, 0f\n"
> >>> + "stp x0, x1, [x15]\n"
> >>> + "stp x2, x3, [x15, #16]\n"
> >>> + "0:\n"
> >>> + : "=r" ( rv )
> >>> + : "x0", "x1", "x2", "x3", "x15"
> >>> + return rv;
> >>> diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> >>> index 0000000000..e80cc1e99b
> >>> --- /dev/null
> >>> +++ b/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> >>> @@ -0,0 +1,83 @@
> >>> + * @file
> >>> + * @ingroup RTEMSScoreCPUAArch64
> >>> + * @brief This header file provides API to wrap secure monitor calls (smc).
> >>> + * are met:
> >>> +#ifndef _RTEMS_SCORE_AARCH64_SMC_H
> >>> +#define _RTEMS_SCORE_AARCH64_SMC_H
> >>> +#include <rtems/score/basedefs.h>
> >>> +#ifdef __cplusplus
> >>> +extern "C" {
> >>> +#endif
> >>> + * @defgroup RTEMSScoreCPUAArch64SMC Secure Monitor Call Support
> >>> + * @brief This group provides functions to invoke secure monitor mode.
> >>> + * @brief The return result from smc invocation.
> >>> +typedef struct {
> >>> + uintptr_t x0;
> >>> + uintptr_t x1;
> >>> + uintptr_t x2;
> >>> + uintptr_t x3;
> >>> +} AArch64_SMC_Return;
> >>> + uintptr_t arg0,
> >>> + uintptr_t arg1,
> >>> + uintptr_t arg2,
> >>> + uintptr_t arg3,
> >>> + uintptr_t arg4,
> >>> + uintptr_t arg5,
> >>> + uintptr_t arg6,
> >>> +#ifdef __cplusplus
> >>> +#endif
> >>> +#endif /* _RTEMS_SCORE_AARCH64_SMC_H */
> >>> diff --git a/spec/build/cpukit/cpuaarch64.yml b/spec/build/cpukit/cpuaarch64.yml
> >>> index 70d80f0b6c..1f3f07f0a2 100644
> >>> --- a/spec/build/cpukit/cpuaarch64.yml
> >>> +++ b/spec/build/cpukit/cpuaarch64.yml
> >>> @@ -19,6 +19,7 @@ install:
> >>> - destination: ${BSP_INCLUDEDIR}/rtems/score
> >>> source:
> >>> - cpukit/score/cpu/aarch64/include/rtems/score/aarch64-system-registers.h
> >>> + - cpukit/score/cpu/aarch64/include/rtems/score/aarch64-smc.h
> >>> - cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
> >>> - cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h
> >>> - cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
> >>> @@ -32,6 +33,7 @@ source:
> >>> - cpukit/score/cpu/aarch64/aarch64-exception-default.c
> >>> - cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> >>> - cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
> >>> +- cpukit/score/cpu/aarch64/aarch64-smc.c
> >>> - cpukit/score/cpu/aarch64/aarch64-thread-idle.c
> >>> - cpukit/score/cpu/aarch64/cpu.c
> >>> - cpukit/score/cpu/aarch64/cpu_asm.S
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
