[PATCH 03/35] libfdt: Add support for disabling internal checks
Sebastian Huber
Tue Dec 14 19:37:49 UTC 2021
If libfdt returns -FDT_ERR_INTERNAL that generally indicates a bug in the
library. Add a new assumption for these cases since it should be save to
disable these checks regardless of the input.
Signed-off-by: Simon Glass <sjg at chromium.org>
Suggested-by: David Gibson <david at gibson.dropbear.id.au>
Message-Id: <20200302190255.51426-3-sjg at chromium.org>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
cpukit/dtc/libfdt/fdt_ro.c | 4 ++--
cpukit/dtc/libfdt/libfdt_internal.h | 9 +++++++++
2 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_ro.c b/cpukit/dtc/libfdt/fdt_ro.c
index 194550344a..e03570a56e 100644
--- a/cpukit/dtc/libfdt/fdt_ro.c
+++ b/cpukit/dtc/libfdt/fdt_ro.c
@@ -402,7 +402,7 @@ static const struct fdt_property *fdt_get_property_namelen_(const void *fdt,
const struct fdt_property *prop;
prop = fdt_get_property_by_offset_(fdt, offset, lenp);
- if (!can_assume(VALID_DTB) && !prop) {
+ if (!can_assume(LIBFDT_FLAWLESS) && !prop) {
offset = -FDT_ERR_INTERNAL;
break;
@@ -634,7 +634,7 @@ int fdt_node_depth(const void *fdt, int nodeoffset)
err = fdt_supernode_atdepth_offset(fdt, nodeoffset, 0, &nodedepth);
if (err)
- return (can_assume(VALID_INPUT) || err < 0) ? err :
+ return (can_assume(LIBFDT_FLAWLESS) || err < 0) ? err :
-FDT_ERR_INTERNAL;
return nodedepth;
diff --git a/cpukit/dtc/libfdt/libfdt_internal.h b/cpukit/dtc/libfdt/libfdt_internal.h
index 7999f6a2d4..d4e0bd49c0 100644
--- a/cpukit/dtc/libfdt/libfdt_internal.h
+++ b/cpukit/dtc/libfdt/libfdt_internal.h
@@ -145,6 +145,15 @@ enum {
* device tree is correctly ordered. See fdt_blocks_misordered_().
ASSUME_LIBFDT_ORDER = 1 << 4,
+ * This assumes that libfdt itself does not have any internal bugs. It
+ * drops certain checks that should never be needed unless libfdt has an
+ * undiscovered bug.
+ * This can generally be considered safe to enable.
+ ASSUME_LIBFDT_FLAWLESS = 1 << 5,
2.31.1
