[PATCH 04/35] libfdt: Use VALID_INPUT for FDT_ERR_BADSTATE checks
Sebastian Huber
Tue Dec 14 19:37:50 UTC 2021
This error indicates a logic bug in the code calling libfdt, so VALID_DTB
is not really the right check. Update it to use VALID_INPUT instead.
Signed-off-by: Simon Glass <sjg at chromium.org>
Suggested-by: David Gibson <david at gibson.dropbear.id.au>
Message-Id: <20200302190255.51426-4-sjg at chromium.org>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
cpukit/dtc/libfdt/fdt.c | 2 +-
cpukit/dtc/libfdt/fdt_sw.c | 7 ++++---
2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt.c b/cpukit/dtc/libfdt/fdt.c
index 4419204a86..c28fcc1157 100644
--- a/cpukit/dtc/libfdt/fdt.c
+++ b/cpukit/dtc/libfdt/fdt.c
@@ -33,7 +33,7 @@ int32_t fdt_ro_probe_(const void *fdt)
} else if (fdt_magic(fdt) == FDT_SW_MAGIC) {
/* Unfinished sequential-write blob */
- if (fdt_size_dt_struct(fdt) == 0)
+ if (!can_assume(VALID_INPUT) && fdt_size_dt_struct(fdt) == 0)
return -FDT_ERR_BADSTATE;
} else {
return -FDT_ERR_BADMAGIC;
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index 352193c0a7..26759d5dfb 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -12,7 +12,7 @@
static int fdt_sw_probe_(void *fdt)
- if (!can_assume(VALID_DTB)) {
+ if (!can_assume(VALID_INPUT)) {
if (fdt_magic(fdt) == FDT_MAGIC)
else if (fdt_magic(fdt) != FDT_SW_MAGIC)
@@ -41,7 +41,7 @@ static int fdt_sw_probe_memrsv_(void *fdt)
if (err)
return err;
- if (!can_assume(VALID_DTB) && fdt_off_dt_strings(fdt) != 0)
+ if (!can_assume(VALID_INPUT) && fdt_off_dt_strings(fdt) != 0)
return 0;
@@ -67,7 +67,8 @@ static int fdt_sw_probe_struct_(void *fdt)
if (err)
return err;
- if (fdt_off_dt_strings(fdt) != fdt_totalsize(fdt))
+ fdt_off_dt_strings(fdt) != fdt_totalsize(fdt))
return 0;
2.31.1
