[PATCH 14/35] libfdt: fdt_splice_(): Fix comparison warning
Tue Dec 14 19:38:00 UTC 2021
With -Wsign-compare, compilers warn about a mismatching signedness
in a comparison in fdt_splice_().
Since we just established that oldlen is not negative, we can safely
cast it to an unsigned type.
Signed-off-by: Andre Przywara <andre.przywara at arm.com>
Message-Id: <20200921165303.9115-8-andre.przywara at arm.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_rw.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 93e4a2b563..68887b969a 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -59,7 +59,7 @@ static int fdt_splice_(void *fdt, void *splicepoint, int oldlen, int newlen)
 	if ((oldlen < 0) || (soff + oldlen < soff) || (soff + oldlen > dsize))
 		return -FDT_ERR_BADOFFSET;
-	if ((p < (char *)fdt) || (dsize + newlen < oldlen))
+	if ((p < (char *)fdt) || (dsize + newlen < (unsigned)oldlen))
 	if (dsize - oldlen + newlen > fdt_totalsize(fdt))
 		return -FDT_ERR_NOSPACE;
2.31.1
