[PATCH 15/35] libfdt: fdt_resize(): Fix comparison warning
Tue Dec 14 19:38:01 UTC 2021
With -Wsign-compare, compilers warn about a mismatching signedness
in a comparison in fdt_resize().
A negative buffer size will surely do us no good, so let's rule this
case out first.
In the actual comparison we then know that a cast to an unsigned type is
safe.
Signed-off-by: Andre Przywara <andre.przywara at arm.com>
Message-Id: <20200921165303.9115-10-andre.przywara at arm.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_sw.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index d10a720f94..8de18fd4f9 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -152,6 +152,9 @@ int fdt_resize(void *fdt, void *buf, int bufsize)
 	FDT_SW_PROBE(fdt);
+	if (bufsize < 0)
+		return -FDT_ERR_NOSPACE;
 	headsize = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt);
 	tailsize = fdt_size_dt_strings(fdt);
@@ -159,7 +162,7 @@ int fdt_resize(void *fdt, void *buf, int bufsize)
 	    headsize + tailsize > fdt_totalsize(fdt))
 		return -FDT_ERR_INTERNAL;
-	if ((headsize + tailsize) > bufsize)
+	if ((headsize + tailsize) > (unsigned)bufsize)
 	oldtail = (char *)fdt + fdt_totalsize(fdt) - tailsize;
2.31.1
