[PATCH 18/35] libfdt: fdt_move(): Fix comparison warnings
Tue Dec 14 19:38:04 UTC 2021
With -Wsign-compare, compilers warn about a mismatching signedness
in comparisons in fdt_move().
This stems from "bufsize" being passed in as a signed integer, even
though we would expect a buffer size to be positive.
Short of changing the prototype, check that bufsize is not negative, and
cast it to an unsigned type in the comparison.
Signed-off-by: Andre Przywara <andre.przywara at arm.com>
Message-Id: <20201001164630.4980-3-andre.przywara at arm.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/cpukit/dtc/libfdt/fdt.c b/cpukit/dtc/libfdt/fdt.c
index 04e1e062f2..6cf2fa03b0 100644
--- a/cpukit/dtc/libfdt/fdt.c
+++ b/cpukit/dtc/libfdt/fdt.c
@@ -314,9 +314,12 @@ const char *fdt_find_string_(const char *strtab, int tabsize, const char *s)
 int fdt_move(const void *fdt, void *buf, int bufsize)
+	if (!can_assume(VALID_INPUT) && bufsize < 0)
+		return -FDT_ERR_NOSPACE;
 	FDT_RO_PROBE(fdt);
-	if (fdt_totalsize(fdt) > bufsize)
+	if (fdt_totalsize(fdt) > (unsigned int)bufsize)
 	memmove(buf, fdt, fdt_totalsize(fdt));
2.31.1
