[PATCH 17/35] libfdt: fdt_add_string_(): Fix comparison warning
Sebastian Huber
Tue Dec 14 19:38:03 UTC 2021
With -Wsign-compare, compilers warn about a mismatching signedness
in a comparison in fdt_add_string_().
Make all variables unsigned, and express the negative offset trick via
subtractions in the code.
Signed-off-by: Andre Przywara <andre.przywara at arm.com>
Message-Id: <20201001164630.4980-2-andre.przywara at arm.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
cpukit/dtc/libfdt/fdt_sw.c | 14 +++++++-------
1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index 8de18fd4f9..354f46674b 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -250,18 +250,18 @@ int fdt_end_node(void *fdt)
static int fdt_add_string_(void *fdt, const char *s)
char *strtab = (char *)fdt + fdt_totalsize(fdt);
- int strtabsize = fdt_size_dt_strings(fdt);
- int len = strlen(s) + 1;
- int struct_top, offset;
+ unsigned int strtabsize = fdt_size_dt_strings(fdt);
+ unsigned int len = strlen(s) + 1;
+ unsigned int struct_top, offset;
- offset = -strtabsize - len;
+ offset = strtabsize + len;
struct_top = fdt_off_dt_struct(fdt) + fdt_size_dt_struct(fdt);
- if (fdt_totalsize(fdt) + offset < struct_top)
+ if (fdt_totalsize(fdt) - offset < struct_top)
return 0; /* no more room :( */
- memcpy(strtab + offset, s, len);
+ memcpy(strtab - offset, s, len);
fdt_set_size_dt_strings(fdt, strtabsize + len);
- return offset;
+ return -offset;
/* Must only be used to roll back in case of error */
2.31.1
