[PATCH 26/35] libfdt: Tweak description of assume-aligned load helpers
Sebastian Huber
Tue Dec 14 19:38:12 UTC 2021
From: David Gibson <david at gibson.dropbear.id.au>
There's a small inaccuracy in the comment describing these new helpers.
This corrects it, and reformats while we're there.
Fixes: f98f28ab ("libfdt: Internally perform potentially unaligned loads")
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
cpukit/dtc/libfdt/libfdt_internal.h | 14 +++++++-------
1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/cpukit/dtc/libfdt/libfdt_internal.h b/cpukit/dtc/libfdt/libfdt_internal.h
index 8b580aa507..16bda1906a 100644
--- a/cpukit/dtc/libfdt/libfdt_internal.h
+++ b/cpukit/dtc/libfdt/libfdt_internal.h
@@ -47,13 +47,13 @@ static inline struct fdt_reserve_entry *fdt_mem_rsv_w_(void *fdt, int n)
- * Internal helpers to access tructural elements of the device tree blob
- * (rather than for exaple reading integers from within property values). We
- * assume that we are either given a naturally aligned address for the platform
- * or if we are not, we are on a platform where unaligned memory reads will be
- * handled in a graceful manner. If this is not the case there are _unaligned
- * versions of these functions that follow and can be used.
+ * Internal helpers to access tructural elements of the device tree
+ * blob (rather than for exaple reading integers from within property
+ * values). We assume that we are either given a naturally aligned
+ * address for the platform or if we are not, we are on a platform
+ * where unaligned memory reads will be handled in a graceful manner.
+ * If not the external helpers fdtXX_ld() from libfdt.h can be used
+ * instead.
static inline uint32_t fdt32_ld_(const fdt32_t *p)
2.31.1
