[PATCH 27/35] Set last_comp_version correctly in new dtb and fix potential version issues in fdt_open_into
Sebastian Huber
Tue Dec 14 19:38:13 UTC 2021
Changes in v3:
- Remove noop version sets
- Set version correctly on loaded fdt in fdt_open_into
Fixes: f1879e1a50eb ("Add limited read-only support for older (V2 and V3) device tree to libfdt.")
Signed-off-by: Justin Covell <jujugoboom at gmail.com>
Message-Id: <20201229041749.2187-1-jujugoboom at gmail.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
cpukit/dtc/libfdt/fdt_rw.c | 4 +++-
cpukit/dtc/libfdt/fdt_sw.c | 2 +-
cpukit/include/libfdt.h | 1 +
3 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 68887b969a..f13458d165 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -428,12 +428,14 @@ int fdt_open_into(const void *fdt, void *buf, int bufsize)
if (can_assume(LATEST) || fdt_version(fdt) >= 17) {
struct_size = fdt_size_dt_struct(fdt);
- } else {
+ } else if (fdt_version(fdt) == 16) {
struct_size = 0;
while (fdt_next_tag(fdt, struct_size, &struct_size) != FDT_END)
if (struct_size < 0)
return struct_size;
+ } else {
+ return -FDT_ERR_BADVERSION;
if (can_assume(LIBFDT_ORDER) ||
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index 68b543c4df..4c569ee7eb 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -377,7 +377,7 @@ int fdt_finish(void *fdt)
fdt_set_totalsize(fdt, newstroffset + fdt_size_dt_strings(fdt));
/* And fix up fields that were keeping intermediate state. */
- fdt_set_last_comp_version(fdt, FDT_FIRST_SUPPORTED_VERSION);
+ fdt_set_last_comp_version(fdt, FDT_LAST_COMPATIBLE_VERSION);
fdt_set_magic(fdt, FDT_MAGIC);
return 0;
diff --git a/cpukit/include/libfdt.h b/cpukit/include/libfdt.h
index 2bc16a8b3f..73467f75c5 100644
--- a/cpukit/include/libfdt.h
+++ b/cpukit/include/libfdt.h
@@ -14,6 +14,7 @@ extern "C" {
#endif
#define FDT_FIRST_SUPPORTED_VERSION 0x02
+#define FDT_LAST_COMPATIBLE_VERSION 0x10
#define FDT_LAST_SUPPORTED_VERSION 0x11
/* Error codes: informative error codes */
2.31.1
