[PATCH 28/35] libfdt: Fix a possible "unchecked return value" warning
Tue Dec 14 19:38:14 UTC 2021
From: David Gibson <david at gibson.dropbear.id.au>
Apparently the unchecked return value of the first fdt_next_tag() call in
fdt_add_subnode_namelen() is tripping Coverity Scan in some circumstances,
although it appears not to for the scan on our project itself.
This fdt_next_tag() should always return FDT_BEGIN_NODE, since otherwise
the fdt_subnode_offset_namelen() above would have returned BADOFFSET or
BADSTRUCTURE.
Still, add a check to shut Coverity up, gated by a can_assume() to avoid
bloat in small builds.
Reported-by: Ryan Long <ryan.long at oarcorp.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_rw.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index f13458d165..2fbb545f9c 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -349,7 +349,10 @@ int fdt_add_subnode_namelen(void *fdt, int parentoffset,
 		return offset;
 	/* Try to place the new node after the parent's properties */
-	fdt_next_tag(fdt, parentoffset, &nextoffset); /* skip the BEGIN_NODE */
+	tag = fdt_next_tag(fdt, parentoffset, &nextoffset);
+	/* the fdt_subnode_offset_namelen() should ensure this never hits */
+	if (!can_assume(LIBFDT_FLAWLESS) && (tag != FDT_BEGIN_NODE))
+		return -FDT_ERR_INTERNAL;
 	do {
 		offset = nextoffset;
 		tag = fdt_next_tag(fdt, offset, &nextoffset);
2.31.1
