[PATCH rtems-libbsd] Import arm64 in_cksum.h correctly
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Dec 15 16:05:36 UTC 2021
When this file was brought in, it came from the wrong location or
freebsd-org hash. This corrects the file such that freebsd-to-rtems.py
runs cleanly.
freebsd/sys/arm64/include/machine/in_cksum.h | 43 +++-----------------
1 file changed, 6 insertions(+), 37 deletions(-)
diff --git a/freebsd/sys/arm64/include/machine/in_cksum.h b/freebsd/sys/arm64/include/machine/in_cksum.h
index d55b838b..522ba005 100644
--- a/freebsd/sys/arm64/include/machine/in_cksum.h
+++ b/freebsd/sys/arm64/include/machine/in_cksum.h
@@ -1,6 +1,4 @@
- * SPDX-License-Identifier: BSD-3-Clause
* Copyright (c) 1990 The Regents of the University of California.
* All rights reserved.
@@ -31,7 +29,6 @@
* from tahoe: in_cksum.c 1.2 86/01/05
* from: Id: in_cksum.c,v 1.8 1995/12/03 18:35:19 bde Exp
- * from: src/sys/alpha/include/in_cksum.h,v 1.7 2005/03/02 21:33:20 joerg
* $FreeBSD$
@@ -40,44 +37,16 @@
#include <sys/cdefs.h>
+#ifdef _KERNEL
#define in_cksum(m, len) in_cksum_skip(m, len, 0)
+u_short in_addword(u_short sum, u_short b);
+u_short in_cksum_skip(struct mbuf *m, int len, int skip);
+u_int do_cksum(const void *, int);
#if defined(IPVERSION) && (IPVERSION == 4)
- * It it useful to have an Internet checksum routine which is inlineable
- * and optimized specifically for the task of computing IP header checksums
- * in the normal case (where there are no options and the header length is
- * therefore always exactly five 32-bit words.
-#ifdef __CC_SUPPORTS___INLINE
-static __inline void
-in_cksum_update(struct ip *ip)
- int __tmpsum;
- __tmpsum = (int)ntohs(ip->ip_sum) + 256;
- ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16));
-#else
-#define in_cksum_update(ip) \
- do { \
- int __tmpsum; \
- __tmpsum = (int)ntohs(ip->ip_sum) + 256; \
- ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16)); \
- } while(0)
-#endif
+u_int in_cksum_hdr(const struct ip *);
#endif
-#ifdef _KERNEL
-#if defined(IPVERSION) && (IPVERSION == 4)
-u_int in_cksum_hdr(const struct ip *ip);
-#endif
-u_short in_addword(u_short sum, u_short b);
u_short in_pseudo(u_int sum, u_int b, u_int c);
-u_short in_cksum_skip(struct mbuf *m, int len, int skip);
-#endif
+#endif /* _KERNEL */
#endif /* _MACHINE_IN_CKSUM_H_ */
2.30.2
