[PATCH rtems-libbsd] Import arm64 in_cksum.h correctly
Thu Dec 16 04:07:08 UTC 2021
OK
Thanks
On 16/12/21 3:05 am, Kinsey Moore wrote:
> When this file was brought in, it came from the wrong location or
> freebsd-org hash. This corrects the file such that freebsd-to-rtems.py
> runs cleanly.
>  freebsd/sys/arm64/include/machine/in_cksum.h | 43 +++-----------------
>  1 file changed, 6 insertions(+), 37 deletions(-)
> diff --git a/freebsd/sys/arm64/include/machine/in_cksum.h b/freebsd/sys/arm64/include/machine/in_cksum.h
> index d55b838b..522ba005 100644
> --- a/freebsd/sys/arm64/include/machine/in_cksum.h
> +++ b/freebsd/sys/arm64/include/machine/in_cksum.h
> @@ -1,6 +1,4 @@
> - * SPDX-License-Identifier: BSD-3-Clause
>   * Copyright (c) 1990 The Regents of the University of California.
>   * All rights reserved.
> @@ -31,7 +29,6 @@
>   *	from tahoe:	in_cksum.c	1.2	86/01/05
>   *	from:		@(#)in_cksum.c	1.3 (Berkeley) 1/19/91
>   *	from: Id: in_cksum.c,v 1.8 1995/12/03 18:35:19 bde Exp
> - *	from: src/sys/alpha/include/in_cksum.h,v 1.7 2005/03/02 21:33:20 joerg
>   * $FreeBSD$
> @@ -40,44 +37,16 @@
>  #include <sys/cdefs.h>
> +#ifdef _KERNEL
>  #define	in_cksum(m, len)	in_cksum_skip(m, len, 0)
> +u_short in_addword(u_short sum, u_short b);
> +u_short in_cksum_skip(struct mbuf *m, int len, int skip);
> +u_int do_cksum(const void *, int);
>  #if defined(IPVERSION) && (IPVERSION == 4)
> - * It it useful to have an Internet checksum routine which is inlineable
> - * and optimized specifically for the task of computing IP header checksums
> - * in the normal case (where there are no options and the header length is
> - * therefore always exactly five 32-bit words.
> -#ifdef __CC_SUPPORTS___INLINE
> -static __inline void
> -in_cksum_update(struct ip *ip)
> -	int __tmpsum;
> -	__tmpsum = (int)ntohs(ip->ip_sum) + 256;
> -	ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16));
> -#else
> -#define	in_cksum_update(ip)						\
> -	do {								\
> -		int __tmpsum;						\
> -		__tmpsum = (int)ntohs(ip->ip_sum) + 256;		\
> -		ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16));	\
> -	} while(0)
> -#endif
> +u_int in_cksum_hdr(const struct ip *);
>  #endif
> -#ifdef _KERNEL
> -#if defined(IPVERSION) && (IPVERSION == 4)
> -u_int in_cksum_hdr(const struct ip *ip);
> -#endif
> -u_short in_addword(u_short sum, u_short b);
>  u_short in_pseudo(u_int sum, u_int b, u_int c);
> -u_short in_cksum_skip(struct mbuf *m, int len, int skip);
> -#endif
> +#endif /* _KERNEL */
>  #endif /* _MACHINE_IN_CKSUM_H_ */
