[PATCH] score: _Objects_Build_name() signed/unsigned char
Joel Sherrill
joel at rtems.org
Tue Feb 2 16:43:10 UTC 2021
On Tue, Feb 2, 2021 at 10:22 AM Gedare Bloom <gedare at rtems.org> wrote:
> OK. This one surprised me (and I'm sure I'm not the only one.)
Agreed. Did this show up as a warning or Coverity issue?
> On Tue, Feb 2, 2021 at 7:42 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Change _Objects_Build_name() so that the result is independent of the
>> signedness of char.
>> Close #4228.
>> cpukit/include/rtems/score/object.h | 8 ++++----
>> 1 file changed, 4 insertions(+), 4 deletions(-)
>> diff --git a/cpukit/include/rtems/score/object.h
>> b/cpukit/include/rtems/score/object.h
>> index 28a2140521..c8243323a6 100644
>> --- a/cpukit/include/rtems/score/object.h
>> +++ b/cpukit/include/rtems/score/object.h
>> @@ -242,10 +242,10 @@ typedef enum {
>> * @param[in] _C4 is the fourth character of the name
>> #define _Objects_Build_name( _C1, _C2, _C3, _C4 ) \
>> - ( (uint32_t)(_C1) << 24 | \
>> - (uint32_t)(_C2) << 16 | \
>> - (uint32_t)(_C3) << 8 | \
>> - (uint32_t)(_C4) )
>> + ( (uint32_t) (uint8_t) (_C1) << 24 | \
>> + (uint32_t) (uint8_t) (_C2) << 16 | \
>> + (uint32_t) (uint8_t) (_C3) << 8 | \
>> + (uint8_t) (_C4) )
>> * @brief Returns the API portion of the ID.
>> 2.26.2
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210202/1ecd3a7c/attachment.html>
