[PATCH v2] bsps/shared/ofw: Fix coverity reported defects
Niteesh G. S.
niteesh.gs at gmail.com
Wed Feb 3 09:46:19 UTC 2021
Hello,
Please ignore this patch.
Thanks,
Niteesh.
On Wed, Feb 3, 2021 at 3:14 PM G S Niteesh Babu <niteesh.gs at gmail.com>
wrote:
> Fixed use after free and null pointer dereference defects
> FIXES:
> 1) CID 1472601 (NULL_RETURNS)
> 2) CID 1472600 (USE_AFTER_FREE)
> 3) CID 1472599 (USE_AFTER_FREE)
> 4) CID 1472598 (USE_AFTER_FREE)
> 5) CID 1472596 (USE_AFTER_FREE)
> 6) CID 1472597 (ARRAY_VS_SINGLETON)
> 7) CID 1472595 (ARRAY_VS_SINGLETON)
> bsps/shared/ofw/ofw.c | 14 +++++++-------
> 1 file changed, 7 insertions(+), 7 deletions(-)
> diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
> index 82924b2600..126a86cc55 100644
> --- a/bsps/shared/ofw/ofw.c
> +++ b/bsps/shared/ofw/ofw.c
> @@ -313,7 +313,7 @@ ssize_t rtems_ofw_get_prop_alloc(
> if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
> - rtems_ofw_free(buf);
> + rtems_ofw_free(*buf);
> *buf = NULL;
> return -1;
> @@ -344,7 +344,7 @@ ssize_t rtems_ofw_get_prop_alloc_multi(
> *buf = NULL;
> return -1;
> @@ -373,7 +373,7 @@ ssize_t rtems_ofw_get_enc_prop_alloc(
> if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
> *buf = NULL;
> return -1;
> @@ -404,7 +404,7 @@ ssize_t rtems_ofw_get_enc_prop_alloc_multi(
> *buf = NULL;
> return -1;
> @@ -500,7 +500,7 @@ static phandle_t rtems_ofw_get_effective_phandle(
> phandle_t child;
> - phandle_t ref;
> + phandle_t ref[1];
> for (child = rtems_ofw_child(node); child != 0; child =
> rtems_ofw_peer(child)) {
> ref = rtems_ofw_get_effective_phandle(child, xref);
> @@ -533,7 +533,7 @@ phandle_t rtems_ofw_node_from_xref( phandle_t xref )
> phandle_t rtems_ofw_xref_from_node( phandle_t node )
> - phandle_t ref;
> + phandle_t ref[1];
> if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref)) == -1
> rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref, sizeof(ref)) ==
> -1 &&
> @@ -614,7 +614,7 @@ int rtems_ofw_get_reg(
> offset = rtems_fdt_phandle_to_offset(parent);
> ptr = fdt_getprop(fdtp, offset, "ranges", &len);
> - if (len < 0) {
> + if (ptr == NULL) {
> break;
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210203/e3d90092/attachment.html>
