[PATCH v3] bsps/shared/ofw: Fix coverity reported defects
G S Niteesh Babu
niteesh.gs at gmail.com
Wed Feb 3 09:47:53 UTC 2021
Fixed use after free and null pointer dereference defects
FIXES:
1) CID 1472601 (NULL_RETURNS)
2) CID 1472600 (USE_AFTER_FREE)
3) CID 1472599 (USE_AFTER_FREE)
4) CID 1472598 (USE_AFTER_FREE)
5) CID 1472596 (USE_AFTER_FREE)
6) CID 1472597 (ARRAY_VS_SINGLETON)
7) CID 1472595 (ARRAY_VS_SINGLETON)
bsps/shared/ofw/ofw.c | 36 ++++++++++++++++++------------------
1 file changed, 18 insertions(+), 18 deletions(-)
diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
index 82924b2600..ccd57e36af 100644
--- a/bsps/shared/ofw/ofw.c
+++ b/bsps/shared/ofw/ofw.c
@@ -313,7 +313,7 @@ ssize_t rtems_ofw_get_prop_alloc(
if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
- rtems_ofw_free(buf);
+ rtems_ofw_free(*buf);
*buf = NULL;
return -1;
@@ -344,7 +344,7 @@ ssize_t rtems_ofw_get_prop_alloc_multi(
*buf = NULL;
return -1;
@@ -373,7 +373,7 @@ ssize_t rtems_ofw_get_enc_prop_alloc(
if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
*buf = NULL;
return -1;
@@ -404,7 +404,7 @@ ssize_t rtems_ofw_get_enc_prop_alloc_multi(
*buf = NULL;
return -1;
@@ -500,21 +500,21 @@ static phandle_t rtems_ofw_get_effective_phandle(
phandle_t child;
- phandle_t ref;
+ phandle_t ref[1];
for (child = rtems_ofw_child(node); child != 0; child = rtems_ofw_peer(child)) {
- ref = rtems_ofw_get_effective_phandle(child, xref);
- if (ref != -1)
- return ref;
+ ref[0] = rtems_ofw_get_effective_phandle(child, xref);
+ if (ref[0] != -1)
+ return ref[0];
- if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref)) == -1 &&
- rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref, sizeof(ref)) == -1 &&
- rtems_ofw_get_enc_prop(child, "linux,phandle", &ref, sizeof(ref)) == -1
+ if (rtems_ofw_get_enc_prop(child, "phandle", ref, sizeof(ref)) == -1 &&
+ rtems_ofw_get_enc_prop(child, "ibm,phandle", ref, sizeof(ref)) == -1 &&
+ rtems_ofw_get_enc_prop(child, "linux,phandle", ref, sizeof(ref)) == -1
continue;
- if (ref == xref)
+ if (ref[0] == xref)
return child;
@@ -533,16 +533,16 @@ phandle_t rtems_ofw_node_from_xref( phandle_t xref )
phandle_t rtems_ofw_xref_from_node( phandle_t node )
- phandle_t ref;
+ phandle_t ref[1];
- if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref)) == -1 &&
- rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref, sizeof(ref)) == -1 &&
- rtems_ofw_get_enc_prop(node, "linux,phandle", &ref, sizeof(ref)) == -1)
+ if (rtems_ofw_get_enc_prop(node, "phandle", ref, sizeof(ref)) == -1 &&
+ rtems_ofw_get_enc_prop(node, "ibm,phandle", ref, sizeof(ref)) == -1 &&
+ rtems_ofw_get_enc_prop(node, "linux,phandle", ref, sizeof(ref)) == -1)
return node;
- return ref;
+ return ref[0];
phandle_t rtems_ofw_instance_to_package( ihandle_t instance )
@@ -614,7 +614,7 @@ int rtems_ofw_get_reg(
offset = rtems_fdt_phandle_to_offset(parent);
ptr = fdt_getprop(fdtp, offset, "ranges", &len);
- if (len < 0) {
+ if (ptr == NULL) {
break;
2.17.1
