Unable to use make command to build "Hello world" Program
Rohan kumar krohan8870 at gmail.com
Wed Feb 3 15:42:04 UTC 2021
Okay Joel thanks for your help and I will surly check this ticket.
On Wed, Feb 3, 2021 at 8:33 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Feb 3, 2021 at 8:29 AM Rohan kumar <krohan8870 at gmail.com> wrote:
>> Actually I followed this document
>> https://docs.rtems.org/branches/master/user/start/bsp-build.html#quickstartbspbuild-manual to
>> build bsp manually
>> as mentioned in the "GSoc getting started" blog.
>>  Also yes when I run "./waf" command "Waf: Leaving directory
>> `/home/rohan/devlopment/src/rtems/build/sparc/erc32'
>> " this was the final output as you said.
>> But I am actually stuck in running Hello world program
>> https://docs.rtems.org/branches/master/user/start/gsoc.html#prove-you-can-work-on-rtems this
>> document says to run "make" command but the folder "/build/b-erc32" is
>> empty. So I was confused about how to run Hello world.
> It should be under rtems/build. Do a "find build -name hello.exe" and then
> follow the remaining instructions.
> Unfortunately, I think this is a specific example of
> https://devel.rtems.org/ticket/4130 which when filed said there were more
> than a few references to the old build system in the documentation. If you
> can provide a patch for the docs to reflect the current waf procedure, that
> would be appreciated. Good exercise for GSoC preparation. :)
> --joel
>> On Wed, Feb 3, 2021 at 6:36 PM Joel Sherrill <joel at rtems.org> wrote:
>>> On Wed, Feb 3, 2021, 6:43 AM Rohan kumar <krohan8870 at gmail.com> wrote:
>>>> Hello all,
>>>> I am trying to run Hello World program but when run the command "make"
>>>> to build, the error came "make: *** No targets specified and no makefile
>>>> found.  Stop". Actually there is nothing in the "/build/b-erc32" folder
>>>> its just empty and
>>> I'm not sure what you did. The mention of b-erc32 hints at configure and
>>> autotools but you mention waf. Waf leaves the results in rtems/build and
>>> you run waf again.
>>> This seems to be mixing the old and new build infrastructure
>>> instructions.
>>> Is there something that needs more attention in the documentation as we
>>> move to waf only?
>>> also there in the step "Test a BSP" I got two failures too.
>>> These results look pretty good. Minimum probably needs to be addressed
>>> from a tester perspective and sometimes the DL tests fail as the tools
>>> update.
>>>> Passed:        557
>>>> Failed:          2
>>>> User Input:      6
>>>> Expected Fail:   1
>>>> Indeterminate:   0
>>>> Benchmark:       3
>>>> Timeout:         0
>>>> Test too long:   0
>>>> Invalid:         0
>>>> Wrong Version:   0
>>>> Wrong Build:     0
>>>> Wrong Tools:     0
>>>> Total:         569
>>>> Failures:
>>>>  dl06.exe
>>>>  minimum.exe
>>>> User Input:
>>>>  capture.exe
>>>>  dl10.exe
>>>>  top.exe
>>>>  fileio.exe
>>>>  termios.exe
>>>>  monitor.exe
>>>> Expected Fail:
>>>>  psxfenv01.exe
>>>> Benchmark:
>>>>  linpack.exe
>>>>  dhrystone.exe
>>>>  whetstone.exe
>>>> Average test time: 0:00:00.283888
>>>> Testing time     : 0:02:41.532720
>>>> I am currently working on the master branch and trying to build
>>>> sparc-erc32. Do I have to run the ./waf again I am not sure any direction
>>>> will be very helpful.
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210203/6eb6968c/attachment.html>
