[PATCH v3] bsps/shared/ofw: Fix coverity reported defects
Niteesh G. S.
niteesh.gs at gmail.com
Wed Feb 3 17:43:41 UTC 2021
On Wed, Feb 3, 2021 at 11:05 PM Gedare Bloom <gedare at rtems.org> wrote:
> Is this second patch ok to check?
Yes, please go through this patch.
Again adding a link to the patch to avoid confusion
https://lists.rtems.org/pipermail/devel/2021-February/064203.html
Thanks,
Niteesh.
On Wed, Feb 3, 2021 at 2:48 AM G S Niteesh Babu <niteesh.gs at gmail.com>
> wrote:
>> Fixed use after free and null pointer dereference defects
>> FIXES:
>> 1) CID 1472601 (NULL_RETURNS)
>> 2) CID 1472600 (USE_AFTER_FREE)
>> 3) CID 1472599 (USE_AFTER_FREE)
>> 4) CID 1472598 (USE_AFTER_FREE)
>> 5) CID 1472596 (USE_AFTER_FREE)
>> 6) CID 1472597 (ARRAY_VS_SINGLETON)
>> 7) CID 1472595 (ARRAY_VS_SINGLETON)
>> bsps/shared/ofw/ofw.c | 36 ++++++++++++++++++------------------
>> 1 file changed, 18 insertions(+), 18 deletions(-)
>> diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
>> index 82924b2600..ccd57e36af 100644
>> --- a/bsps/shared/ofw/ofw.c
>> +++ b/bsps/shared/ofw/ofw.c
>> @@ -313,7 +313,7 @@ ssize_t rtems_ofw_get_prop_alloc(
>> if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
>> - rtems_ofw_free(buf);
>> + rtems_ofw_free(*buf);
>> *buf = NULL;
>> return -1;
>> @@ -344,7 +344,7 @@ ssize_t rtems_ofw_get_prop_alloc_multi(
>> *buf = NULL;
>> return -1;
>> @@ -373,7 +373,7 @@ ssize_t rtems_ofw_get_enc_prop_alloc(
>> if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
>> *buf = NULL;
>> return -1;
>> @@ -404,7 +404,7 @@ ssize_t rtems_ofw_get_enc_prop_alloc_multi(
>> *buf = NULL;
>> return -1;
>> @@ -500,21 +500,21 @@ static phandle_t rtems_ofw_get_effective_phandle(
>> phandle_t child;
>> - phandle_t ref;
>> + phandle_t ref[1];
>> for (child = rtems_ofw_child(node); child != 0; child =
>> rtems_ofw_peer(child)) {
>> - ref = rtems_ofw_get_effective_phandle(child, xref);
>> - if (ref != -1)
>> - return ref;
>> + ref[0] = rtems_ofw_get_effective_phandle(child, xref);
>> + if (ref[0] != -1)
>> + return ref[0];
>> - if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref)) ==
>> -1 &&
>> - rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref, sizeof(ref))
>> == -1 &&
>> - rtems_ofw_get_enc_prop(child, "linux,phandle", &ref,
>> sizeof(ref)) == -1
>> + if (rtems_ofw_get_enc_prop(child, "phandle", ref, sizeof(ref)) == -1
>> + rtems_ofw_get_enc_prop(child, "ibm,phandle", ref, sizeof(ref))
>> == -1 &&
>> + rtems_ofw_get_enc_prop(child, "linux,phandle", ref, sizeof(ref))
>> == -1
>> continue;
>> - if (ref == xref)
>> + if (ref[0] == xref)
>> return child;
>> @@ -533,16 +533,16 @@ phandle_t rtems_ofw_node_from_xref( phandle_t xref )
>> phandle_t rtems_ofw_xref_from_node( phandle_t node )
>> - phandle_t ref;
>> + phandle_t ref[1];
>> - if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref)) == -1
>> - rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref, sizeof(ref))
>> == -1 &&
>> - rtems_ofw_get_enc_prop(node, "linux,phandle", &ref, sizeof(ref))
>> == -1)
>> + if (rtems_ofw_get_enc_prop(node, "phandle", ref, sizeof(ref)) == -1
>> + rtems_ofw_get_enc_prop(node, "ibm,phandle", ref, sizeof(ref)) ==
>> -1 &&
>> + rtems_ofw_get_enc_prop(node, "linux,phandle", ref, sizeof(ref))
>> == -1)
>> return node;
>> - return ref;
>> + return ref[0];
>> phandle_t rtems_ofw_instance_to_package( ihandle_t instance )
>> @@ -614,7 +614,7 @@ int rtems_ofw_get_reg(
>> offset = rtems_fdt_phandle_to_offset(parent);
>> ptr = fdt_getprop(fdtp, offset, "ranges", &len);
>> - if (len < 0) {
>> + if (ptr == NULL) {
>> break;
>> 2.17.1
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210203/f375af07/attachment.html>
