[PATCH docs] user: remove old build system cmd
Niteesh G. S. niteesh.gs at gmail.com
Wed Feb 3 17:53:53 UTC 2021
On Wed, Feb 3, 2021 at 11:13 PM Joel Sherrill <joel at rtems.org> wrote:
> Was there a mkdir b-erc32 near there in those instructions?
No. All references to the build system in the GSoC section refer to the new
build system
Though there is an unnecessary instruction to create a dir in the manual
BSP build section
under quick start.
mkdir -p $HOME/quick-start/build/b-erc32
> On Wed, Feb 3, 2021, 11:33 AM Gedare Bloom <gedare at rtems.org> wrote:
>> pushed, thx
>> On Wed, Feb 3, 2021 at 10:27 AM G S Niteesh Babu <niteesh.gs at gmail.com>
>> wrote:
>>>  user/start/gsoc.rst | 4 ++--
>>>  1 file changed, 2 insertions(+), 2 deletions(-)
>>> diff --git a/user/start/gsoc.rst b/user/start/gsoc.rst
>>> index f8167b9..2c7df7c 100644
>>> --- a/user/start/gsoc.rst
>>> +++ b/user/start/gsoc.rst
>>> @@ -114,8 +114,8 @@ running `make` in the BSP build directory.
>>>  .. code-block:: none
>>> -  cd $HOME/quick-start/build/b-erc32
>>> -  make
>>> +  cd $HOME/quick-start/src/rtems
>>> +  ./waf
>>>  If you are happy with your changes you can commit the changes and send
>>> the patch
>>>  to :r:list:`devel`.
>>> 2.17.1
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210203/ac39b408/attachment-0001.html>
