[PATCH] common/waf: fix some typos
Gedare Bloom
gedare at rtems.org
Wed Feb 3 17:31:43 UTC 2021
common/waf.py | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/waf.py b/common/waf.py
index 2610235..3806209 100644
--- a/common/waf.py
+++ b/common/waf.py
@@ -269,7 +269,7 @@ def cmd_configure(ctx):
ctx.fatal('Unsupported latex engine: %s' % (conf.latex_engine))
ctx.env.BUILD_PDF = 'yes'
- ctx.envBUILD_SINGLEHTML = 'no'
+ ctx.env.BUILD_SINGLEHTML = 'no'
if ctx.options.singlehtml:
check_inliner = not ctx.env.BIN_INLINER
if check_inliner:
@@ -279,7 +279,7 @@ def cmd_configure(ctx):
ctx.fatal("Node.js inliner is required install with 'npm install -g inliner' " +
"(https://github.com/remy/inliner)")
- ctx.envBUILD_PLANTUML = 'no'
+ ctx.env.BUILD_PLANTUML = 'no'
if ctx.options.plantuml:
check_plantuml = not ctx.env.BIN_PUML
if check_plantuml:
@@ -289,7 +289,7 @@ def cmd_configure(ctx):
ctx.fatal("Node.js puml is required install with 'npm install -g node-plantuml' " +
"(https://www.npmjs.com/package/node-plantuml)")
- ctx.envBUILD_DITAA = 'no'
+ ctx.env.BUILD_DITAA = 'no'
if ctx.options.ditaa:
# We use DITAA via PlantUML
2.25.1
