hello world project
Gedare Bloom
gedare at rtems.org
Wed Feb 3 19:20:27 UTC 2021
Thanks, please send me a git patch of your modification.
On Wed, Feb 3, 2021 at 10:40 AM Ayushman Mishra <ayushvidushi01 at gmail.com>
wrote:
> Good evening everyone Ayushman here,
> I modified the program present in
> $HOME/quick-start/src/rtems/build/sparc/erc32/testsuites/samples/hello.exe
> by changing the init.c file in hello testsuite , then again build the
> BSP using ./waf file as there is no build file available in b-erc32/ .
> Also there is tar sim option is not available in sparc-rtems6-gdb , so
> i used sis ($ sparc-rtems6-sis -gdb) on default port 1234 then
> connected the sparc-rtems6-gdb hello.exe to sis ( (gdb) target
> extended-remote localhost:1234) .
> I have attached the screenshot of output of modified program (HELLO
> FRIEND) output as proof of work .
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210203/9030fd82/attachment-0001.html>
