hello world project
Ayushman Mishra ayushvidushi01 at gmail.com
Wed Feb 3 17:40:06 UTC 2021
Good evening everyone Ayushman here,
I modified the program present in
$HOME/quick-start/src/rtems/build/sparc/erc32/testsuites/samples/hello.exe
by changing the init.c file in hello testsuite , then again build the
BSP using ./waf file as there is no build file available in b-erc32/ .
Also there is tar sim option is not available in sparc-rtems6-gdb , so
i used sis ($ sparc-rtems6-sis -gdb) on default port 1234 then
connected the sparc-rtems6-gdb hello.exe to sis ( (gdb) target
extended-remote localhost:1234) .
I have attached the screenshot of output of modified program (HELLO
FRIEND) output as proof of work .
Name: Screenshot from 2021-02-03 22-21-51.png
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210203/3d4473fd/attachment-0001.png>
