Waf build error
Gedare Bloom
gedare at rtems.org
Wed Feb 3 21:11:51 UTC 2021
Yes,
- testsuites/psxftw01/psxftw01
is incorrect in your psxftw01.yml
<https://github.com/eshandhawan51/rtems/commit/73c2014c42a559c70fb432092c7de55aec1eddff#diff-f55b4a4fc1dae7d87d3295d2329964583705575f6458375063a97e59c606fa7c>
Probably just fix that.
On Wed, Feb 3, 2021 at 2:01 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> Hello everyone,
> I was adding ftw test for waf build and got this error
> /home/nolife/development/rtems/kernel/rtems/testsuites/psxtests/psxftw01/init.c:54:10:
> fatal error: psxftw01-tar.h: No such file or directory
> 54 | #include "psxftw01-tar.h"
> compilation terminated.
> Waf: Leaving directory
> `/home/nolife/development/rtems/kernel/rtems/build/arm/xilinx_zynq_a9_qemu'
> Build failed
> -> task in 'testsuites/psxtests/psxftw01/init.o' failed with exit status
> 1 (run with -v to display more information)
> but the file psxftw01-tar.h is already build and present in the build
> folder.
> the test compile is same as libtests/tar01
> also the test works fine in the old build system
> link to commit :
> Thanks
> - Eshan
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210203/193008d5/attachment-0001.html>
