Waf build error
Wed Feb 3 21:12:59 UTC 2021
also, this looks wrong: "testsuites/psxftw01/psxftw01.exe"
On Wed, Feb 3, 2021 at 2:11 PM Gedare Bloom <gedare at rtems.org> wrote:
> Yes,
> - testsuites/psxftw01/psxftw01
> is incorrect in your psxftw01.yml
> <https://github.com/eshandhawan51/rtems/commit/73c2014c42a559c70fb432092c7de55aec1eddff#diff-f55b4a4fc1dae7d87d3295d2329964583705575f6458375063a97e59c606fa7c>
> Probably just fix that.
> On Wed, Feb 3, 2021 at 2:01 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> Hello everyone,
>> I was adding ftw test for waf build and got this error
>> /home/nolife/development/rtems/kernel/rtems/testsuites/psxtests/psxftw01/init.c:54:10:
>> fatal error: psxftw01-tar.h: No such file or directory
>>    54 | #include "psxftw01-tar.h"
>> compilation terminated.
>> Waf: Leaving directory
>> `/home/nolife/development/rtems/kernel/rtems/build/arm/xilinx_zynq_a9_qemu'
>> Build failed
>>  -> task in 'testsuites/psxtests/psxftw01/init.o' failed with exit status
>> 1 (run with -v to display more information)
>> but the file psxftw01-tar.h is already build and present in the build
>> folder.
>> the test compile is same as libtests/tar01
>> also the test works fine in the old build system
>> link to commit :
>> Thanks
>> - Eshan
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210203/5d84982d/attachment.html>
