[PATCH v2] Test suite for FTW.H methods
Eshan Dhawan
eshandhawan51 at gmail.com
Wed Feb 3 21:34:16 UTC 2021
Signed-off-by: Eshan Dhawan <eshandhawan51 at gmail.com>
spec/build/testsuites/psxtests/grp.yml | 2 +
spec/build/testsuites/psxtests/psxftw01.yml | 34 ++++
testsuites/psxtests/Makefile.am | 26 +++
testsuites/psxtests/configure.ac | 1 +
testsuites/psxtests/psxftw01/init.c | 204 ++++++++++++++++++++
testsuites/psxtests/psxftw01/psxftw01.doc | 18 ++
testsuites/psxtests/psxftw01/psxftw01.scn | 10 +
testsuites/psxtests/psxftw01/psxftw01.tar | Bin 0 -> 3584 bytes
8 files changed, 295 insertions(+)
create mode 100644 spec/build/testsuites/psxtests/psxftw01.yml
create mode 100644 testsuites/psxtests/psxftw01/init.c
create mode 100644 testsuites/psxtests/psxftw01/psxftw01.doc
create mode 100644 testsuites/psxtests/psxftw01/psxftw01.scn
create mode 100644 testsuites/psxtests/psxftw01/psxftw01.tar
diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
index 47dedac275..fb7ce465ae 100644
--- a/spec/build/testsuites/psxtests/grp.yml
+++ b/spec/build/testsuites/psxtests/grp.yml
@@ -109,6 +109,8 @@ links:
uid: psxfile02
- role: build-dependency
uid: psxfilelock01
+- role: build-dependency
+ uid: psxftw01
uid: psxgetattrnp01
diff --git a/spec/build/testsuites/psxtests/psxftw01.yml b/spec/build/testsuites/psxtests/psxftw01.yml
new file mode 100644
index 0000000000..c8b2a4fb59
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxftw01.yml
@@ -0,0 +1,34 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: script
+cflags: []
+copyrights:
+- Copyright (C) 2020 Eshan Dhawan
+cppflags: []
+do-build: |
+ path = "testsuites/psxtests/psxftw01/"
+ tar = path + "psxftw01.tar"
+ tar_gz = self.gzip(bld, tar)
+ tar_xz = self.xz(bld, tar)
+ tar_c, tar_h = self.bin2c(bld, tar)
+ tar_gz_c, tar_gz_h = self.bin2c(bld, tar_gz)
+ tar_xz_c, tar_xz_h = self.bin2c(bld, tar_xz)
+ objs = []
+ objs.append(self.cc(bld, bic, tar_c))
+ objs.append(self.cc(bld, bic, tar_gz_c))
+ objs.append(self.cc(bld, bic, tar_xz_c))
+ objs.append(self.cc(bld, bic, path + "init.c", deps=[tar_h, tar_gz_h, tar_xz_h], cppflags=bld.env.TEST_psxftw01_CPPFLAGS))
+ objs.append(self.cc(bld, bic, "testsuites/psxtests/psxfile01/test_cat.c", target=path + "test_cat.o"))
+ self.link_cc(bld, bic, objs, "testsuites/psxtests/psxftw01.exe")
+do-configure: null
+enabled-by: true
+includes:
+- testsuites/psxtests/psxftw01
+ldflags: []
+links: []
+prepare-build: null
+prepare-configure: null
+stlib: []
+type: build
+use-after:
+- z
+use-before: []
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index d89bcd8801..a35f00b665 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -453,6 +453,32 @@ psxfilelock01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxfilelock01) \
$(support_includes)
endif
+if TEST_psxftw01
+psx_tests += psxftw01
+psx_screens += psxftw01/psxftw01.scn
+psx_docs += psxftw01/psxftw01.doc
+psxftw01_SOURCES = psxftw01/init.c psxfile01/test_cat.c \
+ psxftw01-tar.c psxftw01-tar.h psxftw01-tar-gz.c psxftw01-tar-gz.h
+psxftw01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxftw01) \
+ $(support_includes) $(test_includes) -I$(top_srcdir)/include
+psxftw01_LDADD = $(RTEMS_ROOT)cpukit/librtemscpu.a $(RTEMS_ROOT)cpukit/libz.a $(LDADD)
+psxftw01-tar.c: psxftw01/psxftw01.tar
+ $(AM_V_GEN)$(BIN2C) -C $< $@
+psxftw01-tar.h: psxftw01/psxftw01.tar
+ $(AM_V_GEN)$(BIN2C) -H $< $@
+psxftw01-tar.o: psxftw01-tar.c psxftw01-tar.h
+psxftw01.tar.gz: psxftw01/psxftw01.tar
+ $(AM_V_GEN)$(GZIP) < $< > $@
+psxftw01-tar-gz.c: psxftw01.tar.gz
+psxftw01-tar-gz.h: psxftw01.tar.gz
+CLEANFILES += psxftw01.tar psxftw01-tar.c psxftw01-tar.h \
+ psxftw01.tar.gz psxftw01-tar-gz.c psxftw01-tar-gz.h
+psxftw01/init.c: psxftw01-tar.h psxftw01-tar-gz.h $(TAR01_XZ_H)
+endif
if TEST_psxgetattrnp01
psx_tests += psxgetattrnp01
psx_screens += psxgetattrnp01/psxgetattrnp01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 139787cccb..3f95010cd3 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -90,6 +90,7 @@ RTEMS_TEST_CHECK([psxfenv01])
RTEMS_TEST_CHECK([psxfile01])
RTEMS_TEST_CHECK([psxfile02])
RTEMS_TEST_CHECK([psxfilelock01])
+RTEMS_TEST_CHECK([psxftw01])
RTEMS_TEST_CHECK([psxgetattrnp01])
RTEMS_TEST_CHECK([psxgetrusage01])
RTEMS_TEST_CHECK([psxglobalcon01])
diff --git a/testsuites/psxtests/psxftw01/init.c b/testsuites/psxtests/psxftw01/init.c
index 0000000000..bc3858395f
--- /dev/null
+++ b/testsuites/psxtests/psxftw01/init.c
@@ -0,0 +1,204 @@
+ * @file
+ * @brief Test suite for ftw.h methods
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 Eshan Dhawan, embedded brains GmbH, Joel Sherrill
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+/* Header files */
+#include <bsp.h> /* for device driver prototypes */
+#include "tmacros.h"
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include <rtems/untar.h>
+#include <rtems/error.h>
+#include <ftw.h>
+#include <dirent.h>
+#include <sys/stat.h>
+#include <errno.h>
+#include <unistd.h>
+#include <string.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <rtems/test.h>
+#include "psxftw01-tar.h"
+#include "psxftw01-tar-gz.h"
+#define TARFILE_START psxftw01_tar
+#define TARFILE_SIZE psxftw01_tar_size
+#define TARFILE_GZ_START psxftw01_tar_gz
+#define TARFILE_GZ_SIZE psxftw01_tar_gz_size
+const char rtems_test_name[] = "psxftw01";
+/* Function decleration to avoid warning */
+void *POSIX_Init (void * argument);
+static char file_traverse_order[6][20];
+static int file_order;
+static char buffer[512];
+static const T_action actions[] = {
+ T_report_hash_sha256,
+ T_check_task_context,
+ T_check_file_descriptors,
+ T_check_rtems_barriers,
+ T_check_rtems_extensions,
+ T_check_rtems_message_queues,
+ T_check_rtems_partitions,
+ T_check_rtems_periods,
+ T_check_rtems_regions,
+ T_check_rtems_semaphores,
+ T_check_rtems_tasks,
+ T_check_rtems_timers,
+ T_check_posix_keys
+static const T_config config = {
+ .name = "psxftw01",
+ .buf = buffer,
+ .buf_size = sizeof(buffer),
+ .putchar = rtems_put_char,
+ .verbosity = T_VERBOSE,
+ .now = T_now_clock,
+ .action_count = T_ARRAY_SIZE(actions),
+ .actions = actions
+static int fn_function (const char *fpath, const struct stat *sb,
+int tflag, struct FTW *ftwbuf)
+ strcpy(file_traverse_order [file_order], fpath + ftwbuf->base) ;
+ file_order = file_order + 1;
+ return 0; /* to make nftw run further */
+T_TEST_CASE(ftw)
+ /* VARIABLE DECLEARATION */
+ int r;
+ char *files_path;
+ int flags;
+ int i;
+ /* setting up filesystem */
+ rtems_status_code sc;
+ /*Untaring from memory */
+ sc = Untar_FromMemory_Print(
+ (void *)TARFILE_START,
+ TARFILE_SIZE,
+ &rtems_test_printer
+ if (sc != RTEMS_SUCCESSFUL) {
+ printf ("error: untar failed: %s\n", rtems_status_text (sc));
+ /* Array with expected file order */
+ char arr_ftw_depth[5][20] = { "test_file", "test_script", "def", "abc", "home" };
+ char arr_ftw_phys[5][20] = { "home", "test_file", "abc", "def", "test_script" };
+ /* defining the path to run nftw*/
+ files_path = "/home";
+ /* nftw test with FTW_DEPTH flag*/
+ flags = 0;
+ file_order = 0;
+ flags |= FTW_DEPTH;
+ r = nftw( files_path, fn_function, 5, flags );
+ T_quiet_psx_success(r);
+ /*comparing the nftw file tree to the expexted file tree traversal */
+ for (i = 0; i < file_order; i++){
+ r = strcmp( arr_ftw_depth[i], file_traverse_order[i]);
+ if (r){
+ printf( "Incorrect Order " );
+ /*----------------Test Block 2--------------------*/
+ flags = 0;
+ file_order = 0;
+ flags |= FTW_PHYS;
+ /*comparing the nftw file tree to the expected file tree traversal*/
+ r = strcmp( arr_ftw_phys[i], file_traverse_order[i]);
+ if (r){
+ int exit_code;
+ TEST_BEGIN();
+ T_register();
+ exit_code = T_main(&config);
+ if (exit_code == 0) {
+ TEST_END();
+ rtems_test_exit(exit_code);
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 6
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#include <rtems/confdefs.h>
+/* end of file */
diff --git a/testsuites/psxtests/psxftw01/psxftw01.doc b/testsuites/psxtests/psxftw01/psxftw01.doc
index 0000000000..7b2863a2da
--- /dev/null
+++ b/testsuites/psxtests/psxftw01/psxftw01.doc
@@ -0,0 +1,18 @@
+# COPYRIGHT (c) 2019
+# On-Line Applications Research Corporation (OAR).
+# SPDX-License-Identifier: BSD-2-Clause
+This file describes the directives and concepts tested by this test set.
+test set name: psxftw01
+Directives:
+nftw
+Concepts:
++ This test exercises the ftw.h methods.
diff --git a/testsuites/psxtests/psxftw01/psxftw01.scn b/testsuites/psxtests/psxftw01/psxftw01.scn
index 0000000000..650d365033
--- /dev/null
+++ b/testsuites/psxtests/psxftw01/psxftw01.scn
@@ -0,0 +1,10 @@
+*** BEGIN OF TEST psxftw01 ***
+untar: memory at 0x12608c (10240)
+untar: file: home/test_file (s:73,m:0644)
+untar: file: home/abc/def/test_script (s:21,m:0755)
+untar: symlink: home/test_file -> symlink
+*** END OF TEST psxftw01 ***
diff --git a/testsuites/psxtests/psxftw01/psxftw01.tar b/testsuites/psxtests/psxftw01/psxftw01.tar
index 0000000000000000000000000000000000000000..e45d10793a9fbcadc7d1ee84d42d13ff8eb2655e
GIT binary patch
literal 3584
zcmeHJ!EVAZ4DFe(@U-)WlQ!uW?6}Lu9R)~fM4C=@nZ)1Eq3gsD8sbnuTCGY}>(?ZH
z$+J_|m7TVh+Iiu;O$ISU)L8}z$~2RB;5iUY2mvD1LQAC(Q$V4$zyxrR)f^4FrPeeF
zBH4wZ)|oIbj}YDKs;-O+uqE5jDL|JBC$~2^1-Zv>v(gdpV;~*^s0;A5S-G$V6X0$3
z^7;<(V9<_QTS3v(6$d6RIHt-2QwOdxYx_L8$K=K}on at em`ZtT^bY+XK4$!i3AMM#6
zF95J2a;2g)M6RO#e|#qvlo~|FMM7yQ8Nm8amAtb4L+xGhM*%z+?{(k%3;4Mu^zi{K
zl`Lsb at Z=2vAB4|Q%(vW<tIkck%Db=`bk3;%JU{6B{XO7Y{_KADe~DZN5|I1iH1Or*
TpZEVkH+~#^WME|At{M0OLN<HT
literal 0
HcmV?d00001
2.27.0
