[PATCH] Basic lwIP for STM32H7 BSP
Robin Müller
robin.mueller.m at gmail.com
Thu Feb 4 12:18:07 UTC 2021
I think the DMA descriptors need to be 32 byte (0x20) aligned. That's the
reason the example application was set up like this.
Kind Regards
Robin
On Wed, 3 Feb 2021 at 15:32, Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Feb 3, 2021, 8:26 AM Robin Müller <robin.mueller.m at gmail.com>
> wrote:
>> Also, Andrei Chichak provided a very good explanation:
>> The STM32x7 ethernet controllers need their descriptors and data areas to
>>> be located on 32-byte boundaries with a combination of cache being turned
>>> off and buffering being turned off. This is a side effect of the STM32x7
>>> DMA and data caching.
>>> The examples that ST have for LWiP under FreeRTOS have some issues with
>>> the linker file having overlapping sections and the stack (above the ETH
>>> data areas) being left with no cache and no buffering. The space above the
>>> rx/tx buffers is also less than the stack space minimum specified in the
>>> linker file as well. Some rearranging of the ETH descriptors and data
>>> areas would be prudent. Like push them to the top of SRAM and locate the
>>> stack below.
>>> To get this all going, they set up the MPU for two overlapping sections,
>>> one being the top 16kB of SRAM and the other the 256B that contain the ETH
>>> descriptors. I believe the MPU regions can be set in increments of 32Bytes,
>>> so setting up the cache and buffering should be do-able without affecting
>>> the stack.
> Just asking. Can this be a non-cacheable region and the variables not in
> special sections? I wonder if changing them to normal pointers to special
> memory would ripple. Do they just use the variables for initialization or
> reference them a lot?
> I think the standard linkcmds setup allows for nocache areas already.
> --joel
>> Kind Regards
>> Robin Müller
>> On Wed, 3 Feb 2021 at 14:50, Robin Müller <robin.mueller.m at gmail.com>
>> wrote:
>>> The following link contains more theoretical information about why these
>>> sections were placed at these addresses:
>>> https://community.st.com/s/article/FAQ-DMA-is-not-working-on-STM32H7-devices
>>> Kind Regards
>>> Robin
>>> On Wed, 3 Feb 2021 at 14:44, Robin Müller <robin.mueller.m at gmail.com>
>>> wrote:
>>>> The DMA descriptors need to be placed at the start of the SRAM3 and
>>>> need to be aligned in a certain way. The RX buffer will take up the first
>>>> (slightly less than) 16 kB of SRAM3 but needs to be placed
>>>> behind the DMA descriptors. It also needs to be placed in a way that
>>>> the MPU configuration required for the DMA descriptors will not do
>>>> something with the RX buffers.
>>>> In the example provided by STM32, the first 256 bytes are configured by
>>>> MPU Config.
>>>> Kind Regards
>>>> Robin
>>>> On Wed, 3 Feb 2021 at 13:43, Sebastian Huber <
>>>> sebastian.huber at embedded-brains.de> wrote:
>>>>> On 02/02/2021 20:10, Robin Mueller wrote:
>>>>> > + /* Not an ideal solution but required for lwIP on the STM32H7
>>>>> BSP.
>>>>> > + This places the DMA descriptors for lwIP at the start of SRAM3.
>>>>> > + The MPU still needs to be configured for the DMA descriptor
>>>>> regions to be
>>>>> > + bufferable, non-cacheable, non-shareable (first 256 bytes) */
>>>>> > + .lwip_sec_stm32h7 (NOLOAD) : ALIGN_WITH_INPUT {
>>>>> > + . = ABSOLUTE(0x30040000);
>>>>> > + *(.RxDecripSection)
>>>>> > + . = ABSOLUTE(0x30040060);
>>>>> > + *(.TxDecripSection)
>>>>> > + . = ABSOLUTE(0x30040200);
>>>>> > + *(.RxArraySection)
>>>>> > + } >SRAM_3 AT> REGION_TEXT_LOAD
>>>>> This is the wrong linker command file. This stuff should be in
>>>>> spec/build/bsps/arm/stm32h7/linkcmdsmemory.yml
>>>>> with an output section name like ".stm32h7_sram_3" and corresponding
>>>>> input section names. Why do you need absolute addresses here?
>>>>> embedded brains GmbH
>>>>> Herr Sebastian HUBER
>>>>> Dornierstr. 4
>>>>> 82178 Puchheim
>>>>> Germany
>>>>> email: sebastian.huber at embedded-brains.de
>>>>> phone: +49-89-18 94 741 - 16
>>>>> fax: +49-89-18 94 741 - 08
>>>>> Registergericht: Amtsgericht München
>>>>> Registernummer: HRB 157899
>>>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>>>>> Unsere Datenschutzerklärung finden Sie hier:
>>>>> https://embedded-brains.de/datenschutzerklaerung/
>>>>> _______________________________________________
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210204/b027632f/attachment.html>
